5.9 magnum flex plate
Old May 27, 2024 | 10:18 PM
Spooderboss2000's Avatar
Spooderboss2000
Default 5.9 magnum flex plate
Recently i had done a torque converter replacement on my 46re paired with the 5.9 magnum, and the other day my truck was making a sound just like rod knock, so i assumed ot was the rocker tick that it has so i changed the oil and topped it off cause it was low, didnt change anything then i check the flex plate and ir has a crack on one side i checked all around and checked the bolts they look fine.
my question is for the flex plate can i drive it to school like this for 3 days straight or is it bad, im also wondering dumb question i know but would cutting a little more off so it doesnt make metal contact as it’s broken be fine i just dont like the knocking its making
Old May 28, 2024 | 08:27 AM
Don't think I would be cutting anything in there, noise or no..... If it isn't real far to school, then you'll prolly be ok. But, if it's a long trip..... I'd be lookin' for somethin' else to drive until that is fixed.
