Cooper Discoverer H/T Plus Tire Feedback
Old Jul 16, 2010 | 11:46 PM
  #21
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by blakeroberts88
How long do you think they will last? If you say 50,000+ I will buy them.
Not on my truck they won't.....
Old Feb 5, 2012 | 05:53 PM
  #22
DaveCinHutto's Avatar
DaveCinHutto
Default How much in wheel weights do the Coopers use
I have run Cooper tires before and found them to be of such good quality that I would like to try some for my Ram1500 with the 20s. How many wheel weights are you seeing mounted on your 20 inch rims?
Dead thread nacromonger.
Old Feb 6, 2012 | 09:53 AM
  #23
bog8r's Avatar
bog8r
When I bought my "08 there were 2 new Discoverer H/Ts on it, so I put 2 more. I have the 20" rims and the installer had trouble getting 1 of the tires to balance. But he got it right and they don't make noticable amount of noise and so far they handle well in city type driving.
Old Feb 7, 2012 | 11:41 AM
  #24
DaveCinHutto
Since I could not find any Coopers in stock around here I opted for Sumitomos, they balanced out with .75 oz, .5 oz, .25 oz and .7oz. They are quite on a concrete road, it is not raining here, so when it does I well get a chance on testing them. It is a truck and not a sports car so I can not give you a reply on handling.
Old Apr 22, 2012 | 09:51 AM
  #25
72combo's Avatar
72combo
I have had these about a month sorry, Cooper Discoverer HT Plus and its like a different truck I pulled my GY Wranglers off at 20k kms which is not very many miles and was the best thing I could have done theses Coopers give a very confident feeling, no give on turns and curves.Highway speeds absolutely no vibes.I was skeptical but seeing both tires brand new side by side off a wheel the OEM GOODYEARS shooed a flat spot inside and the side wall was flimsy.Now the Cooper was heavier and not flimsy at all, not flat spot with these .
Old Apr 22, 2012 | 09:53 AM
  #26
72combo's Avatar
72combo
I have a question, How would you feel towing a6000 lbs travel trailer with the Cooper Discover HR plus tires?
Old Apr 23, 2012 | 11:25 PM
  #27
DaveCinHutto
I find the Sumitomos work excellent in the rain, even on worn smooth blacktop, very quite on the concrete slab. I had to have the tires rebalanced, I detected an ever so slight vibration, seems that the wheel guy got the weights on in the wrong location. Put a half bottle of water on the console, it should have no or intermittent ripples on a smooth road.
Mileage of a tire is dependent upon load and type of driving. I have traction control so wheel spin is not happening, love it in slicker than snot conditions. I typically do not haul heavy loads so I can expect excellent wear.
Old May 6, 2012 | 09:22 AM
  #28
72combo's Avatar
72combo
Update...around a thousand miles and well the only problem I am finding is the tread in prone to holding stones so you get a click, click click until you hit the highway and it flies out, or you pull over and inspect....every 10 minutes LOL
