Lowering front end only
Old Apr 2, 2007 | 10:33 PM
harleyman7's Avatar
harleyman7
Default Lowering front end only
I have a 07 Ram quad caband would like to lower the front at least one inch or maybe two inches for a little more rake look. It has the 20" wheels. Has anyone lowered the front only.....if so, maybe post a picture. Thanks.
Old Apr 2, 2007 | 11:38 PM
Cordoba man's Avatar
Cordoba man
Default RE: Lowering front end only
If it's 4wd, you can lower it a bit by adusting the bolts at the back of the torsion bars. If it's 2wd, you'll need different springs or a drop spindle.
Old Apr 3, 2007 | 01:33 AM
djr04's Avatar
djr04
07's don't have the same front suspension as the 02-05's so the torsion bar crank may not work. I know my 06 has a coil over IFS, and I would assume the 07 would as well.
Old Apr 3, 2007 | 02:28 AM
harleyman7's Avatar
harleyman7
It's a 2wd. I was wonderingif 2" would be too much on the front. I don't really want to lower the back.
