wiring subs into stock stereo
Old Apr 3, 2007 | 06:34 PM
chrisc2345's Avatar
chrisc2345
Default RE: wiring subs into stock stereo
Sad_drake, I have the MTX thunderform with Two 10 inch subs, I might assume you have a simular system, yours has the built in amp mine does not.
It is preformed to fit the exact dimentions of the storage space under the rear seats. Very nice units.
If your box has a speaker level input you can plug the wires right into the box's amp input, but if it requires a RCA input go the anaudio shop and get a line level converter ($20)
This is a schematic of the Dodge audio harness of the Infinity 7 speaker system (if you don't have this option tel me)
Dodge 2006 Ram Pickup EX. CAB Pickup[/align](PREMIUM SYSTEM)[/align]
RADIO HARNESS
Wire Function
Color
Note
Fuse #
Size
Location
+12V DC Battery(Constant)
Gray/red
Radio pins 1 & 12
11
20 amp
Integrated power module at left front fender
Switched Accessory
Data
Ground
Black
Also black/light green
Left Rear +
Dk.green/dk.blue
Line level output
Left Rear -
Dk.green/orange
Line level output
Right Rear +
Gray/dk.blue
Line level output
Right Rear -
Gray/orange
Line level output
AMPLIFIER OUTPUTS
Wire Function
Color
Note
Fuse #
Size
Location
12V DC Battery
Yellow/red
Amplifier pins C1-4 & C1-13
36
25 amp
Remote Turn On (input)
N/A
See notes for B+ & accessory power to subwoofer amplifier.
Left Front Mid +
Dk.green/yellow
Left Front Mid -
Dk.green/lt.blue
Left Front Tweeter +
Gray/orange
Left Front Tweeter -
Gray/yellow
Right Front Mid +
Gray/yellow
Right Front Mid -
Gray/lt.blue
Right Front Tweeter +
Gray/dk.green
Right Front Tweeter -
Gray/lt.green
Left Rear Mid +
Gray/lt.green
Left Rear Mid -
Gray/dk.green
Right Rear Mid +
Dk.green/lt.green
Right Rear Mid -
Dk.green/gray
Center Channel +
Gray/brown
Center Channel -
Gray/orange
Subwoofer 1 +
Dk.green/tan
To the subwoofer amplifier
Subwoofer 1 -
Gray/tan
AT SPEAKERS
Wire Function
Color
Note
Right Rear Mid +
Gray/lt.green
Or dk.green/lt.green
Right Rear Mid -
Gray/dk.green
Or dk.green/gray
Subwoofer 1 +
Gray/brown
Channel 1 of subwoofer speaker.
Subwoofer 1 -
Dk.green/brown
Subwoofer 2 +
Gray/white
Channel 2 of subwoofer speaker.
Subwoofer 2 -
Dk.green/white
Available Notes
Notes
The SUBWOOFER AMPLIFIER, has B+ at pin 2 (red) with fuse no. 24 of 20 amperes in the integrated power module; the accessory line (pink/yellow) goes to pin 3 & has fuse no. 39 of 10 amperes.
The main amplifier is located at right side of dash, but the woofer amplifier is at left side of body.[/align][/align]
___________________________________________
you will want to tie into the Amp input subwoofer wires drk green/tan wire and the grey/tan wiresThisis a low level input to the factory amp. This is a low freq audio range signal bass only but use the low level freq switch on ht eamp anyway.
You will need to run a key on low amperage power wire for you remote amp wire turn on( the newer amps have a ma voltage sensor and donot requiire this wire). I recommend a Amp install kit, htis will have allwires applicable (power/groundlow awg wires, RCA's, remote wire and battery block and high amp fuse).
I ran my sub in this manner and have been enjoying the bass ever since
Old Apr 3, 2007 | 06:59 PM
chrisc2345's Avatar
chrisc2345
w/o premium system the wires to tie into are;
LF Speaker +/- dk. grn/yel - dk. grn/lt. blue
RF Speaker +/- gray/yellow - gray/lt. blue
LR Speaker +/- gray/lt. grn - gray/dk. grn
RR Speaker +/- dk. grn/lt. grn - dk. grn/gray
You can tie into anyof these wires but if you want the subs to work when you fade the speakers to the front you need to tie into the front speakers
LF Dk/yellow-posand dk green/lt blue for neg
RFgrey/yellow -pos and gray/dkblue for neg
I hope I have helped you
Good luck
Old Jan 6, 2008 | 08:38 AM
bert6573's Avatar
bert6573
is this for a 2007 if not is it similar
Old Jan 7, 2008 | 01:39 AM
mn12sc35gh's Avatar
mn12sc35gh
I just did this on my 07 RC (basic single disc head unit).
Buy a line out converter (even Wal Mart has these, like 20$). Tap the rear outputs (I just used the little clamp splices you can put over your stock wire, I didn't want to cut anything). If you want, you can tap the fronts too, the converter I bought has a front and reap preamp out, if you intend to add anything else, you might as well do the work now :P If it has line out gain settings, turn them up all the way, just be sure to turn the gain on your amp down all the way before you fire it up for the first time. I was able to set the gain on it and the amp all the way up and adjust it with the remote.
Rear outputsare: (from one of the earlier posts, these matched my wiring too).
LR Speaker +/- : gray/lt. grn/ gray/dk. grn
RR Speaker +/- : dk. grn/lt. grn/ dk. grn/gray
While you have the dash apart (theres a good walkthrough in this forum for tearing the dash apart, I added info for the 6-spd people :P), look at the cigar lighter wiring. If your cigar lighter goes off with the ignition off and the door open (like the radio does), you can use this for your remote turn on. Tap the Red/Yellow (maybe orange and yellow, it was dark. Theres only 2 and the other is clearly not it).
Run your remote and preamp to your amp, add in a power and ground, and your good to go.
If the amp has a remote, and you have the little compartment below the radio, those remotes fit pretty well there. If you take the rubber piece out the back, you'll have a decent size hole to run your wire through (I had to carve it open a little.... but the back of the rubber piece covered it all up nicely). I really like being able to adjust the amp level on the dash.
