wiring subs into stock stereo
Old Apr 3, 2007 | 03:22 AM
sad_drake's Avatar
sad_drake
Default wiring subs into stock stereo
i am wanting to wire a set of 8" bazooka subwoofers into my stock 2007 ram 1500 big horn and was needing to know what wiring diagram i need to do so? if anyone has the diagram i would really appreciate it
Old Apr 3, 2007 | 06:06 AM
squidjuice's Avatar
squidjuice
Default RE: wiring subs into stock stereo
i wanted to do this also with my 05' ram 1500 5.7L Hemi..
Old Apr 3, 2007 | 01:05 PM
chrisc2345's Avatar
chrisc2345
I have a few questions for you guys;
1. are you using stock stereo unit
2. is it the high power unit or no added amp unit
Old Apr 3, 2007 | 01:39 PM
bigjrussell's Avatar
bigjrussell
For the 2005:
Radio 12v gray/red+radio harness
Radio Ground black and black/lt. green-radio harness
Radio Ignition pink/yellow+radio harness
Radio Illumination orange/tan (dimmer)+radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
Notes: The amplifier is behind the glove box.
LF Speaker +/- : dk. grn/yel/ dk. grn/lt. blue (+,- radio harness or amplifier)
RF Speaker +/- : gray/yellow/ gray/lt. blue(+,- radio harness or amplifier)
LR Speaker +/- : gray/lt. grn/ gray/dk. grn(+,- radio harness or amplifier)
RR Speaker +/- : dk. grn/lt. grn/ dk. grn/gray (+,- radio harness or amplifier)
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
You may need to look to another souce for your remote turn on. I didan installon my '06 and just used the fuse box under the hood. Just plugged the remote wire into one side of the fuse slot and if the amp turned off when I turned the key off, that was my source. Pretty much guess and check.
I don't have any info for the '07 though, sorry. I would imagine that it wouldn't be too much different from the '06 because they both use the CAN-BUS system, but I can neither confirm nor deny this.
P.S. the12volt.com is a great forum specializing in vehicle wiring and accessories.
Old Apr 3, 2007 | 01:44 PM
aja10415's Avatar
aja10415
Let me knowif this works:
Radio 12vred/lt. blue
Radio Groundblack/yellow
Radio Ignition(CAN data bus)
Radio Illumination N/A
Factory Amp Turn-on (CAN data bus)
Power Antennagray/red
LF Speaker +/-gray/purple- gray/yellow
RF Speaker +/-dk. green/pur- dk. green/yel
LR Speaker +/-dk. grn/dk. blue - dk. grn/brn
RR Speaker +/-gray/dk. blue- gray/orange
Old Apr 3, 2007 | 01:46 PM
aja10415's Avatar
aja10415
For you're remote wire check the12volt.com they should be able to tell you. good luck
Old Apr 3, 2007 | 02:07 PM
sad_drake's Avatar
sad_drake
in my 2007 i am using the stocke stereo unit and the subs have built in amps
Old Apr 3, 2007 | 02:56 PM
mellofone's Avatar
mellofone
Where the heck are you going to put the subs?
Old Apr 3, 2007 | 04:31 PM
sad_drake's Avatar
sad_drake
im putting them in my back floor board since i have the quad cab
Old Apr 3, 2007 | 06:05 PM
joepascoe19's Avatar
joepascoe19
man get rid of the buzooka tubes and ger an mtx thunder form it ia a much cleaner install andwould probely sound better too
