intake is leaking??
Old Apr 6, 2007 | 05:46 PM
Denniss66's Avatar
Denniss66
Default intake is leaking??
I pulled my truck into dodge and they told me that i blew an intake gasket. does anyone know what it would cost for a new one and how easy it would be to take off the intake manifold to change the gasket. dodge estimated me around 300 or more to put a new gasket on does that sound resonable. thanks.
Old Apr 6, 2007 | 06:05 PM
Exchevy's Avatar
Exchevy
Default RE: intake is leaking??
REMOVAL
1. Disconnect negative cable from battery.
2. Remove resonator assembly and air inlet hose.
3. Disconnect electrical connectors for the following components:
²
Manifold Absolute Pressure (MAP) Sensor
²
Intake Air Temperature (IAT) Sensor
²
Throttle Position (TPS) Sensor
²
Coolant Temperature (CTS) Sensor
4. Disconnect brake booster hose and positive crankcase ventilation (PCV) hose.
5. Remove generator and set aside.
NOTE: It is not necessary to remove lines or remove freon from A/C compressor.
6. Remove air conditioning compressor and set aside..
7. Bleed fuel system (Refer to 14 - FUEL SYSTEM/FUEL DELIVERY - STANDARD PROCEDURE).
8. Remove intake manifold retaining fasteners in a crisscross pattern starting from the outside bolts and ending at
the middle bolts.
9. Remove intake manifold and IAFM as an assembly.
CLEANING
NOTE: There is NO approved repair procedure for the intake manifold. If severe damage is found during
inspection, the intake manifold must be replaced.
Before installing the intake manifold thoroughly clean the mating surfaces. Use a suitable cleaning solvent, then air
dry.
9 - 2578 ENGINE - 5.7L - SERVICE INFORMATION
DR
INSPECTION
1. Inspect the intake sealing surface for cracks, nicks and distortion.
2. Inspect the intake manifold vacuum hose fittings for looseness or blockage.
3. Inspect the manifold to throttle body mating surface for cracks, nicks and distortion.
INSTALLATION
1. Install intake manifold seals.
2. Position intake manifold and IAFM.
3. Install intake manifold retaining bolts, and tighten in sequence from the middle bolts towards the outside in a
crisscross pattern. Torque fasteners to 12 N·m (105 in. lbs.).
4. Connect electrical connectors for the following components:
²
²
²
²
²
Idle Air Control (IAC) Motor
5. Install generator.
6. Install A/C compressor.
7. Connect Brake booster hose and Positive crankcase ventilation (PCV) hose.
8. Install resonator assembly and air inlet hose.
9. Connect negative cable to battery.
DR
ENGINE - 5.7L - SERVICE INFORMATION 9 - 2579
Old Apr 6, 2007 | 06:27 PM
djr04's Avatar
djr04
Cost me somewhere in the 400 hundred range to fix the intake gasket on my old blazer, and that was at the employee rate, so I'd say that's a good price.
Old Apr 9, 2007 | 05:15 PM
Denniss66's Avatar
Denniss66
well i found out that when my truck backfired it blew the intake manifold into pieces. i went to dodge and they showed me the manifold and it was made of plastic does anyone know of an aftermarket one that would be better. new manifold from dodge is 150 then he is doing plugs and wires plugs are 50 for 16 and the wires are 160 is there aftermarket ones of those that i should get as well seeings how they got it all apart. when all said and done its gonna cost 793 plus tax in CDN to get it back together.
Old Apr 9, 2007 | 05:25 PM
AU4x4's Avatar
AU4x4
did your engine light come on when the gasket blew ? Also did you have diagnostics hooked up reading "emmisions leak" or anything of the sort? might have the same problem. been told it was my gas cap but its been replaced and light still comes on. let me know. thanks.
Old Apr 9, 2007 | 07:48 PM
bltp203's Avatar
bltp203
When it happened to my 1999 5.9 1500, I found out when I lost all my oil within a week of changing it. I did a vacuum test and verified the problem.
Old Apr 9, 2007 | 09:08 PM
Denniss66's Avatar
Denniss66
the check engine light never came on i turned my key back and forth 3 times and it showed 3 codes p2108 p2172 and p2106. they hooked it up to the diagnostics and it showed a vacuum leak. its not just an intake gasket that blew my intake manifold was broken in two.
