Fog light wont light
Old Apr 6, 2007 | 07:56 PM
samuk's Avatar
samuk
Default Fog light wont light
Just installed the factory kit, but lamps wont light up, am i missing a connection, there was a wire installed already and not sure forgot to connect something
help please
Old Apr 6, 2007 | 08:48 PM
M14's Avatar
M14
Default RE: Fog light wont light
I would simply start checking all connections, check for proper ground, then check for power. Assuming the kit includes a relay, there should be two power connections for the relay - one from battery and the other would be hot when the low beams are on.
Old Apr 6, 2007 | 10:31 PM
samuk's Avatar
samuk
the itens in the kit, two lights, two bezels, one wiring that connects on the hookup in the front, close to the left opening. one switch, but no relay. missing anything here ?
Old Apr 6, 2007 | 10:55 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Grab your mulitmeter and start where you have power and work out from there. Wherever you loose power is you problem spot.
