Light Wiring into the cab??
Hey folks. I'm planning on putting some lights behind the grill like the fellow did in this thread:
https://dodgeforum.com/m_443200/tm.htm
My question is.. what is the best way to bring the wiring into the cab? And where is the best place to install the switch? I'm hoping for some pics, but really any info is greatly appreciated.
Either drill a whole in your firewall or cut a small slit in the rubber surrounding your steering... make sure you silicone this up. If you cut through the firewall use a rubber grommet to keep the insulation on the wire from rubbing away. Make sure you fuse the whole set up, or you will end up with a burned out shell of a truck. As for switch locations, it all based on how you want the end product to look and ease of use. You could run the switch to be next to the factory headlight switch. I mounted a sub control dial to the plastic cover just above the trans hump.
