what is the differance in the 1500 and the 2500 frame
Old Apr 9, 2007 | 11:09 PM
salvagnini07's Avatar
salvagnini07
Default what is the differance in the 1500 and the 2500 frame
I have a 06 Ram 1500 4x4 SLT and i found a brush bar for the front end and they say that it will not bolt onto the 1500 they only make it for the 2500 and the 3500 Rams i would like to know the differance so i would now what to do if I would have to modifty the brush bar or the frame
If anybody has any information about it would be very helpful
Old Apr 9, 2007 | 11:39 PM
The_Bishop's Avatar
The_Bishop
Default RE: what is the differance in the 1500 and the 2500 frame
The frame is very different. The 1500 is independent front suspension, the 2500 is solid front axle. That in and of itself requires a vastly different frame.
Old Apr 10, 2007 | 11:42 PM
salvagnini07
what if u had a hemi in the 2500 would it is be the same thing or would it be different
Old Apr 12, 2007 | 07:35 AM
msm_portata's Avatar
msm_portata
So what is a 1500 MegaCab? I heard that it is actually built on a 2500 frame, not a streched 1500 frame, but it has independent suspension on the front.
Old Apr 12, 2007 | 10:50 AM
Erock509's Avatar
Erock509
ORIGINAL: msm_portata
Yes all the mega cabs are built on the heavy duty frame, but as far as the differences between the 1500's 2500's I dont know, Im sure it has something to do with the front coil springs and the rear leaf springs
Old Apr 12, 2007 | 01:52 PM
Mystro's Avatar
Mystro
2500/3500 Hemiand Diesel uses the same frame.
Old Apr 18, 2007 | 11:31 AM
coats_ne's Avatar
coats_ne
I read online that the mega cab 1500 has the same frame, chassis, axles and wheels as the 2500. I called Dodge customer service and they told me they are essentially the same pickup, but I think I might of been talking to a moron.So Icalled the local dealership and the salesman there said he thought the 2500 had an extra leaf, but I checked. Not true.I have not been able to get a definitive answer from anyone. So if there is anyone who does know for sure what the differences are, let me know. My couriosity has been peaked. My mega cab 1500 sure rides and pulls like a 3/4 ton. I pull a 31ft travel trailer with a GVWR of 7700 lbs and it does it quite well. I've even beenconsidering popping off my 1500 emblems and putting on 2500. My pickup seems to be more of a 2500 than a 1500 anyway. Have you ever seen a half ton pickup with a full floating rear axle?
