MPG: Speed vs. Weight
Old Apr 12, 2007 | 07:28 AM
msm_portata's Avatar
msm_portata
Default MPG: Speed vs. Weight
Just FYI -- Speed kills mileage, not weight.
I get 17 MPG on a flat, straight freeway going 65 MPH with a stock 2006 Mega Cab 4x2, 3.73 rear, Hemi.
With a 7,000 lbs. trailer (V-nose, 22-foot) loaded with race car and stuff, I get 11 MPG at 55 MPH on the same freeway.
With the same trailer unloaded (3,200 lbs), I get 9.5 MPG at 65 MPH.
If you want to get better mileage when towing, just slow down.
Old Apr 12, 2007 | 07:57 AM
hemi06ram's Avatar
hemi06ram
Default RE: MPG: Speed vs. Weight
actually in your case its a lil bit of both.(speed and weight)
Old Apr 13, 2007 | 08:01 PM
tinyfxds's Avatar
tinyfxds
I agree. Just slow down. If you get better gas mileage at 55 than at 65 when you don't have anything in the truck, it'll will be the same when you're towing something. I can get 20mpg in my truck going down the highway at 55-60mph. It drops to 16mpg when I'm doing 70mph
Old Apr 13, 2007 | 09:25 PM
hemiyellow's Avatar
hemiyellow
DC Insider
hell i can get 19 MPG goin down the highway at 70-75, if i slow down to 60-65 it goes up to about 20-21
Old Apr 13, 2007 | 10:43 PM
JimmyDiablo's Avatar
JimmyDiablo
I know that averaging 95-100 I get 15 mph's solid. but when I drive between 55-75 depends on traffic I get aprox 18.2. depends how many red lights I get.
Old Apr 13, 2007 | 11:27 PM
tinyfxds's Avatar
tinyfxds
Where in the world can you drive between 90-100mph? Is it expensive to live there? If not I'll move there.
Old Apr 14, 2007 | 12:25 AM
JimmyDiablo
I was traveling from Los Angeles to Phoenix on my way back.
Old Apr 14, 2007 | 09:26 PM
tinyfxds's Avatar
tinyfxds
What's the posted speed limit? I think up in Montana or Wyoming there's recommended speed limits but it's not really enforced too much. So you can drive faster if you want.
Old Apr 14, 2007 | 09:57 PM
squirtbottle09's Avatar
squirtbottle09
In montana there arnt speed limits on some roads, or if there are there is noone around to see you so they could care less.
Old Apr 15, 2007 | 12:30 AM
cyclone429's Avatar
cyclone429
MPG has nothing to dop with speed or wheight, RPM's, and shift points that move the whieght most efficanitly are mileage makers or breakers.
I get better highway mileage when I tow with the rpms at 2000 in 6th gear at 60 mph vers 1700 to 1900 Rpms at 50 to 55 mph, I tow a smaller tandom travel trailer under 5000 lbs, my mileage would be better if I had a topper on my truck, thiers verry little diferance in my towing mileage empty on flat roads vers empty.
Once I excead 8000 lbs or so, mileage is not great, I still have no issues with speed or power with my 5.7.
tire size, axle ratios and driver input and reserch will not be the same for every Ram.
