TOWING CAPACITY??
Old Apr 23, 2007 | 07:42 AM
CODE3RUN's Avatar
CODE3RUN
Default RE: TOWING CAPACITY??
All depends on the gears. 3.55 has the lesser tow rating. Better gas milage though when not towing. CLICK HERE
Old Apr 23, 2007 | 07:43 AM
CODE3RUN's Avatar
CODE3RUN
I cant get this right but click here........
http://www-5.dodge.com/towing5/D/veh...E+Transmission
Old Apr 23, 2007 | 11:20 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
The link works great. How can you find out your gear ratio that came with your truck?
Old Apr 24, 2007 | 12:57 AM
Silver Eagle's Avatar
Silver Eagle
look in your glove box.There's a sticker that tells you what you want to know.
Old Oct 22, 2007 | 06:31 PM
glenlivet's Avatar
glenlivet
Looked in the glove box. No such sticker! Is there any other way to find out your rear diff ratio? I don't have the original manual for my 05 1500 quad cab.
Old Oct 22, 2007 | 06:48 PM
sspp's Avatar
sspp
ORIGINAL: glenlivet
Go to Dodge website. Go to the "For Owners" tab.There is a customer service e-mailat the "contact us" link. Send them the VIN and request a build sheet. Got mine the next day. There is also an option to enter your VIN at some point. I think it may give you the info right then in PDF format.
Old Oct 23, 2007 | 12:27 AM
sa1765's Avatar
sa1765
ORIGINAL: CODE3RUN
this is for a two wheel drive...4x4 qc w/ 3.92 is about 8500/8700lb.
mine is qc lb 4x4 and 8300lb and i was thinking that the shortbed was two hundred pounds more.
Old May 2, 2014 | 07:59 PM
Bozella's Avatar
Bozella
Question Ram 2500 Big Horn
Anyone know the tow capacity for the 2006 Dodge Ram Big Horn 2500?
Engine 5.9 HO Cummins Turbo Diesel Engine.
4 speed automatic. Front air bags
anti lock 4-wheel disc brakes.
trailer tow group
class IV hitch receiver
11.50 rear axle
I want to pull a 5th wheel if possible. Any info. would be appreciated. Thank you.
Old May 3, 2014 | 08:01 AM
dirtydog's Avatar
dirtydog
Moderate User
trailer tow group
11.50 rear axle
Post #12 above....
