Old Aug 5, 2015, 09:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Volant Cold Air Intake vs other CAI's?
Old Apr 30, 2007 | 11:33 PM
  #21
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Volant Cold Air Intake vs other CAI's?
ORIGINAL: ThaChad
ORIGINAL: 94rt10ohio
To answer the exhaust question above, my recommendation is if you want loud, but something that is not to annoying at highway speeds and idle get the 50 series flowmaster kit. I think they call it American Thunder, working off memory here. You can get it from our sponsor www.jegs.com. I have it on my Hemi, comes with options for dual exit behind the rear tires or dual exit out the back.
My only issue with the Flowmaster Cat-Back system is that it's made from Mandrel Bent Aluminized Steel, Our stock exhaust is Mandrel bent Stainless Steel. So why would I down grade to Aluminized steel?
That's Why I'm thinking, I'm better off to just buy the muffler, and have a shop weld it onto my stainless tubing. The only problem there is that From the muffler back, it'll be compression bent Aluminized Steel, as no shop within 100 miles of here mandrel bends pipe, and none use stainless.
-TheChad
This is true, and also why is is lower priced over others. The downside to the muffer only is you still have to consider removing the resonator and adding pipe to the stock system to shoot out duals.
Old May 5, 2007 | 12:23 AM
  #22
chizel's Avatar
chizel
this Volant cold air intake make sense to me, it gives me more hp than my intake before, i used to have this for almost 7 months and until now i never had a problem with the intake i've chosen..it performs well..love it.
