Warranty & Changing Your Own Oil
Old Apr 23, 2007 | 01:18 PM
M14's Avatar
M14
Default Warranty & Changing Your Own Oil
For those that change their own oil, are there any potential worries regarding the warranty not being upheld? The dealer could not give me a straight answer and I see from reading on this borad Dodge is actively looking for ways not to provid warranty service. I would like to change my own oil in the new truck but have some concerns.
Old Apr 23, 2007 | 01:25 PM
darkrt's Avatar
darkrt
Default RE: Warranty & Changing Your Own Oil
Just keep receipts and records of oil changes. If there is ever an issue,then you have your records.
Old Apr 23, 2007 | 01:46 PM
NYPANAMA42's Avatar
NYPANAMA42
Yup, he's right....Just keep a accurate record of all oil changes, including receipts, and you should be fine.
Old Apr 23, 2007 | 02:00 PM
M14's Avatar
M14
Thanks. I didn't think about the receipts for purchase of the oil & filters, but this as well as maybe the product UPC codes is good advice.
I figure I will have Dodge change the oil the first two times, then I would do the oil, filter, and lube from then on as it is less costly and take less time than taking the truck in.
Old Apr 23, 2007 | 05:42 PM
#Red's Avatar
#Red
Just keep all the receipts in an orderly fashion and don't be late with any oil change and you will be fine. Red
Old Apr 23, 2007 | 09:57 PM
CarGuyOhio's Avatar
CarGuyOhio
In reality receipts does nothing for the back yard mechanic. That oil and filter could have went into any vehicle, proves nothing.
Bottom line is if the oil in the truck at failure time is VERY old it will be obvious, even then it will be hard for DC to void the warranty if you push the issue.
