Going for service
On 5/1/07 I have a appointment for a minor oil leak, I know I have to detune my truck, should I also take off the superchips sticker? Also I know that if it is not directly related it does not void warrunty but should I also remove the cai?
I'd remove the sticker but otherwise just change the programing back to stock and you'll be fine. I wouldn't worry about the intake either unless the problem is directly related to the addition of the intake.
u said detune...so do u have a chip, or did u flash your pcm....idk if its true, but i heard these trucks record how many times the pcm has been flashed...aka, if u flash it, and they dont see pcm flash in their files or anywhere on your trucks history, they will know u flashed your truck...that is, if they even check
definately do not remove your cai.....they would have to prove it messed up your truck to void the warrenty...unless you really are thinkin about trading it in, then thats your call
Leave the CAI, put back to stock flash, leave the sticker. I saw a Hemi badge on a Honda recently, I sure did not think it had a Hemi.
