door speakers help!
Old Apr 26, 2007 | 03:19 AM
hemiguy_20's Avatar
hemiguy_20
Default door speakers help!
i have an 05 dodge ram hemi 2wd 4 door truck. i can not find anywhere that tells me what the size of thestock door speakers are can anyone help? i know the grilles are round but from the little info i can gather two of them are obround. can anyone help??? thanks.
[IMG]local://upfiles/61559/8D06A029D94C4D6BBD81222E46162E3D.jpg[/IMG]
Old Apr 26, 2007 | 03:33 AM
HighDuke1911's Avatar
HighDuke1911
Default RE: door speakers help!
open up the panel and take em into the store or whatever. thatll do the trick.
Old Apr 26, 2007 | 03:42 AM
hozie's Avatar
hozie
Mine were round in back and oblong in front. Cant remember what size but I put a Kicker in both doors in back to replace the stocks, then cut a hole in each door panel and mounted a kicker tweeter in each, and then put a crossover on each side. For the life of me though I can remember what size they were in back. Oh yeah, I also cut out the "gril" that was molded into the door from the factroy so I could use the kicker grill cover piece---it looked cooler IMO.
Old Apr 26, 2007 | 03:43 AM
DeWalt378G's Avatar
DeWalt378G
^^Yeah, I was just gonna say the same thing. ^^ Sounds like you are going to change em out anyway, so just pull the panel. You'll learn more that way (mount, mounting depth).
oops...posted too late.
Old Apr 26, 2007 | 03:54 AM
healy886's Avatar
healy886
6" x 9" in the front, 6" in the back
Old Apr 26, 2007 | 10:41 AM
packman35's Avatar
packman35
www.crutchfield.com. Use the "Outfit my Vehicle" section.
It will tell you everything you want to know.
Old Apr 26, 2007 | 02:53 PM
eltupac's Avatar
eltupac
6x9 front, 5.25 rear
Old Apr 26, 2007 | 04:30 PM
HuntinHanson's Avatar
HuntinHanson
i have 6x9front and 6 1/2 rear
Old Apr 26, 2007 | 06:48 PM
HighDuke1911
ORIGINAL: packman35
crutchfield isnt too good witht hat man. i buy **** from them, but their outfitting of a car is pretty bad.
Old Apr 28, 2007 | 01:59 AM
Duso02's Avatar
Duso02
When in doubt, check the bible.
This is out of the manual:
SPEAKER
DESCRIPTION
STANDARD
The standard equipment speaker system includes
speakers in four locations. One 15.2 X 22.8 centimeter
(6 X 9 inch) full-range speaker is located in each
front door. There is also one full-range 13.3 centimeter
(5.25 inch) diameter full-range speaker located in
each rear door.
PREMIUM
The optional premium speaker system features
eleven Premium model speakers in seven locations.
Each of the standard speakers is replaced with Premium
model speakers. One 8.8 centimeter (3.50 inch)
diameter speaker is located on each end of the
instrument panel top pad. One 6.3 centimeter (2.50
inch) diameter speaker is located in the center of the
instrument panel top pad. One 15.2 X 22.8 centimeter
(6 X 9 inch) Premium speaker is located in each
front door. There is also one coaxial 13.3 centimeter
(5.25 inch) diameter Premium full-range speaker
located in each rear door. The premium speaker system
also includes a power amplifier mounted behind
the glove box. The total available power of the premium
speaker system is 240 watts.
