Brake dust
Old Apr 27, 2007 | 12:23 PM
HerpHandler's Avatar
HerpHandler
Default Brake dust
Is there a product that can be installed behind the rim that will limit the amount of brake dust that gets on the wheel? If so who has them and can they be used on the stock 20's on an '06 1500
Old Apr 27, 2007 | 12:36 PM
oefootball_70's Avatar
oefootball_70
Default RE: Brake dust
i've seen them on fords. i dont know about a dodge
Old Apr 27, 2007 | 03:34 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Upgrade your pads. The cheaper the pad the more dust it will produce. Check to see if you are running with a semi metallic or ceramic pad then go from there. Lots of people will try to save a buck and buy the pads that are around $30.00. They work, but they make a mess.
Old Apr 27, 2007 | 03:57 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
http://www.jcwhitney.com/autoparts/P...010025/c-10614
Old Apr 28, 2007 | 04:19 PM
HuntinHanson's Avatar
HuntinHanson
i really like the ceramic pads i never had brake dust on my old truck
Old Apr 29, 2007 | 02:56 AM
schmedly's Avatar
schmedly
Any deflector product that will deflect the brake dust from coming thru will also prevent thr engineered cooling of the rotors. Say godbye to brake dust and hello to warped rotors. That and surface crackingis what happens as a direct result of overheating.
Old Apr 29, 2007 | 03:19 AM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: HerpHandler
http://www.kleenwheels.com/about_kleenwheels.htm
Old Apr 29, 2007 | 08:30 PM
deanj287's Avatar
deanj287
ceramics will require more pedal effort to apply the same amount of presure as semi metallics. they will also chew the hell out of your rotors and even more so if your hard on the brakes. 5000+ LBS doesnt stop easy
Old Apr 29, 2007 | 08:38 PM
Night_Runner's Avatar
Night_Runner
there is a product i use by michilin (sp) that you apply to your wheels and it helps repell brake dust....i use that and it seems to work well....also, try waxing your wheels after you clean them, ive heard this works well
i would NOT get one of those brake shields such as kleenwheels which blocks brake dust from getting on your wheels because they also block air from getting to your brakes and your brakes may get VERY hot...atleast thats what ive heard
