Thinking of trying Hell Bent Steel 2" Coil Spacer
Old Apr 30, 2007 | 02:14 PM
CtCowboyFan's Avatar
CtCowboyFan
Default Thinking of trying Hell Bent Steel 2" Coil Spacer
Whos tried these http://cgi.ebay.com/ebaymotors/ws/eB...157&rd=1,1
Trying to get the front end more level with back and put air bags on the back..
What are the negatives , like tire wear, longer shocks, warranty worries?
Or no negatives ?
Thank you
Old May 1, 2007 | 03:19 AM
bltp203's Avatar
bltp203
Default RE: Thinking of trying Hell Bent Steel 2" Coil Spacer
Getting an alignment after the install will take care of any tire wear worries. Unless you really put the suspension through its paces off road, then longer shocks are not needed. They only way your warranty claim will be denied is if they can show the spacer caused the problem.
Old Jan 22, 2008 | 11:06 AM
josh213corbs's Avatar
josh213corbs
what kind of truck are you trying to put the 2" spacer on? I'm curious because I was looking into the same thing for my '07 1500 QC. Any suggestions or recommendations? How much would I be looking to spend on a 2" Rancho lift compared to the coil spacers? Thanks for any help.
