few questions
Old May 1, 2007 | 01:23 AM
tpowell3499's Avatar
tpowell3499
Default few questions
just few questions that have been on my mind lately
1) why do people take their chrome wheels off in the winter?
2) Is it really neccessary to get new gears (3.55) if you go from 17" wheels to 20"
3) where can you buy a lift for a 2wd QC that is not 6". I only want a 2 or 3
Old May 1, 2007 | 01:28 AM
HuntinHanson's Avatar
HuntinHanson
Default RE: few questions
1) to avoid them rusting from salt thrown on roads
2) no it is not at all necessary gear size is changed with tire size not rim size
3)not positive on this one, try maybe topguncustomz.com
Old May 1, 2007 | 01:48 AM
HighDuke1911's Avatar
HighDuke1911
well, cant you use most 2-3" lifts on a 4x2 as you would for a 4x4? i mean, isnt it just business? making extra money for false advertising?
Old May 1, 2007 | 11:03 AM
tpowell3499
4x4 lift are not the same for the front end so they will not work. Tire size is going from 265-70 to a 275-60
Old May 1, 2007 | 11:06 AM
hemiyellow's Avatar
hemiyellow
DC Insider
no you wont need to change gears for that small change...just have to go to the dealer and have em reprogram the tire size...unless u have a programmer and you can do it yourself
Old May 1, 2007 | 12:18 PM
FFMedic1479's Avatar
FFMedic1479
Fabtec
Old May 1, 2007 | 06:07 PM
HemiLonestar's Avatar
HemiLonestar
2) Gears do not change, speedo calibration and final drive ratio (combo of rear gear ratio and tire height) changes. Hell, if your 20" tires and rims end up having the same overall diameter, then you don't have to do anything to your speedo!
Old May 1, 2007 | 07:05 PM
Tailbuster's Avatar
Tailbuster
Fabtech makes a good lift for a 4x2 and they have a variety of sizes for different levels of lift. But keep in mind they are expensive.
Superlift also makes some as well as Rough Country. They are both a little cheaper than Fabtech.
All you really need is a leveling kit to raise it 2" or go with a body lift.
