Radiator Fan Relay
Old May 3, 2007 | 04:09 AM
kipanthony's Avatar
kipanthony
Default Radiator Fan Relay
I have a 2002 Dodge Ram Quad Cab 1500 4.7 . Having a little too much fun and going a little too fast through some possibly too high water, my check engine light turned on and I had it checked at Autozone and the code said that the Radiator Fan Relay is shorted or malfunctioning. So I'm looking too see if someone knows where I can find that realy because I did not see it with all the other relays in the "Fuse and Relay center" under the hood. Is it something that I can change easily myself, or should I go ahead and take it somewhere? Thanks!
