Looking for Gunmetal or Black Rims....please give me your sueggestions
Old May 7, 2007 | 04:47 AM
jobookennedy's Avatar
jobookennedy
Default RE: Looking for Gunmetal or Black Rims....please give me your sueggestions
try going to customwheelsunlimited.com they have specific rims called gunmetal as their color
Old May 7, 2007 | 05:52 AM
FastForwardWheels's Avatar
FastForwardWheels
Read this thread, if I can help answer any questions you may have feel free to let me know.....
https://dodgeforum.com/m_793235/mpage_1/key_/tm.htm
-Eli
Old May 7, 2007 | 03:56 PM
HuntinHanson's Avatar
HuntinHanson
i'm not sure about the rim under the platic coating but i really think there was someone on the forum that did it. Try doing a search and see what you can find.
Old May 7, 2007 | 04:17 PM
redram5.9's Avatar
redram5.9
Go with powdercoating. You can choose whatever color you want, including gunmetal or black in a gloss, semi-gloss or flat finish. On top of that it is a much more durable finish.
Old May 7, 2007 | 04:28 PM
FastForwardWheels
ORIGINAL: redram5.9
I don't want to rain on anyone's parade here but I think the hype of powder coating wheels is far beyond what is should be.....
1) Powder Coating is very easy to apply uneven and may need to be done twice.
2) The amount of heat involved in BAKING your wheels to the temp needed to melt the powder is far beyond what is structurely sound
3) Powder Coating tends to chip instead of scratching resulting in complete clumps missing if you accidently mis-handle it.
4) If the powder coater doesn't completely stip, prepare the surface andtemperature warm the surface correctly you'll have trouble in time to come.
Now, not that I deal with wheels all day long or nothing but I felt I should share this with you guys.....
-Eli
Old May 7, 2007 | 04:30 PM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: redram5.9
The problem with powder coating aluminum is that the heat required changes the metalurgy and weakens the metal.
Back in the eary 80s when powder coating became popular there was about a dozen deaths from scuba tanks exploding when being filled. It took them awhile to figure out that the thing they all had in common was that they had all been recently powder coated.
After doing some testing they found that the heat from th powder coat proceess was what was causing the problem.
Old May 7, 2007 | 05:46 PM
redram5.9's Avatar
redram5.9
I have had mine done now for about 2 years, no problems, no chips, no runs, nothing structuraly wrong with the wheel, and still look brand new when I clean them up (leave them on year-round with ice and road treatments in the winter). It sounds like most of the problems you have listed has to do with the quality of your powdercoater.
Old May 7, 2007 | 08:27 PM
spinfreak's Avatar
spinfreak
ORIGINAL: Captain Squalus
ORIGINAL: spinfreak
ORIGINAL: HansonHVAC
If you like the look of the stock rims what about ripping off the plastic pieces and then have them painted or powdercoated?
Does the metal rim underneath look the same as the plastic cover (obviously not chrome though...lol)?
Stock alloy rims are polished then plastic coated to protect the polish.
The anodizing shop can take care of removing the plastic. (they would probily prefer to do it themselves anyway so the polished surface would not be contaminated.
If that's correct, then I'm completely mistaken with what I thought the facotry rims were (which wouldn't be the first time I was wrong...lol). I thought the "rim" underneath was just a plain metal (stell) rim, and there was the plastic cover (almost like a hubcap) over the metal rim. They don't have like a plastic coating, but an actual cap that's over them....at least that's the way they appear to be.
Old May 7, 2007 | 08:45 PM
Captain Squalus
ORIGINAL: spinfreak
ORIGINAL: spinfreak
Do you have the steel or alloy wheels?
I thought you had the alloy.
Old May 7, 2007 | 09:12 PM
spinfreak's Avatar
spinfreak
No idea. They're the factory 2003 20" rims. I've always heard them called as plastic clad rims. I know they do have a plastic "cover" on them....don't know what they are underneath.
