3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
squealing from the rear of the truck and shaking above 50mph. It squeals when I am accelerating and decelerating(goes away at about 35 from what I can tell. It sqeuals when braking and shakes sometimes when I brake(almost feels like abs is kicking in under normal braking). I took it to a mechanic the other day and they immediately said u-joint. So I had that fixed and I still have the same sympotms. Do you have any ideas on what is going on?
I had the same problem with my 02 after the dealer decided to cut my rear rotors. Right after that they replaced them because they warped within a couple of days.
