Strange noise...Sounds like something dragging
Old May 14, 2007 | 08:01 PM
kdough613's Avatar
kdough613
Default RE: Strange noise...Sounds like something dragging
Now there's a smart idea...I'm taking it in to get checked out in the morning though by my mechanic...He's a straight dude, so I figure its the easiest way to find out. Its not like I have either the time or the knowhow to fix it myself anyways likely, so why not save myself the trouble...Still praying its nothing serious though! I told him what it sounded like and he said brakes maybe too though...
Old May 15, 2007 | 08:16 PM
kdough613's Avatar
kdough613
Well...FYI, apparently there's a problem with the joint between my differential and my axles in the front end. I guess something has come loose, and the axles in the front are now sort of floating. My mechanic says he can grab onto the driver's side axle and shift it about 2 1/2" up and down, and almost as much on the other side...This should be a hefty repair bill I'm sure. Thanks for all the input, I'll be sure to keep you posted on how it all shakes down.
Old May 15, 2007 | 08:50 PM
hemi348's Avatar
hemi348
hmm, maybe your spare tire is loose and moving around under there.
Old May 15, 2007 | 09:53 PM
RubberFrog's Avatar
RubberFrog
No, it's not the spare... he just said the front axle was loose.
Old May 15, 2007 | 10:51 PM
kdough613's Avatar
kdough613
Yup, not the spare...That would be too cheap of a fix to be my problem...
