Strange noise...Sounds like something dragging
Old May 13, 2007 | 01:39 PM
kdough613's Avatar
kdough613
Default Strange noise...Sounds like something dragging
I have an '03 QC 1500 and starting about a week ago I've been having this strange noise that sounds like something is dragging, muffler dragging on road kind of sound, but there is NOTHING handing down anywhere NEAR the ground. It only happens at 15km/h and faster, and its really freaking the hell out of me. I also had an incident with my 4x4 a few days before hand, I switched my 4x4 on, and when I shifted from park to drive it made some kind of crazy rattling noise, but it only did it once and I haven't had ANY problems since with it. I'm not sure if its related, but I wouldn't put anything past it at the moment. The dragging noise happens in both 2 AND 4 wheel as well. It seems less obvious when I'm at higher speeds as well, as in highway speeds (55+). I'm clueless...So any ideas/suggestions/gifts from god would be GREATLY appreciated...
Thanks
Old May 13, 2007 | 02:31 PM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
Default RE: Strange noise...Sounds like something dragging
I don't have anything to offer, but that sounds kinda serious. If it is a constant noise, you probaby want to get it checked out ASAP before you do some major damage to something. Sounds like you have some parts rubbing together causing friction where there shouldn't BE friction. It would suck to have something fail at highway speeds.
Old May 13, 2007 | 02:38 PM
NJMandCEM's Avatar
NJMandCEM
The last time any of my cars made a dragging niose... I had to have my brakes done...
Old May 13, 2007 | 02:55 PM
kdough613's Avatar
kdough613
I think I DO need to get my brakes done, they've been squeaking for a lil while...Stupid *** truck, needs new everything! I would be THRILLED if that was the source of my noise, I'm just worried its something more serious.
Old May 13, 2007 | 03:07 PM
NJMandCEM's Avatar
NJMandCEM
Heres what ya do... Go out to your truck and look between the rims and see if your rotors have gouges.. if so.. I'd say the dragging noise is comin from your brakes...
Old May 13, 2007 | 03:29 PM
kdough613's Avatar
kdough613
Nope...No gouges. At least nothing noticeable either to my eye, or when I felt them. It almost sounds like there's something loose and rattling, but I haven't the faintest clue what it could be. Everything looks fine when I get underneath.
Old May 13, 2007 | 05:00 PM
big guy's Avatar
big guy
Something else tolook atwhile looking at the brakes. Check the park brakes in the rear. I had my shoesseperate causing a scraping noise.
Dan
Old May 13, 2007 | 06:29 PM
NJMandCEM's Avatar
NJMandCEM
Maybe... Just maybe... You need to check your muffler bearings...
hehe
Old May 13, 2007 | 08:12 PM
crashedcdo's Avatar
crashedcdo
jack up the truck. all four corners. make sure your jack stands are secure. get in the truck, start it, and put it in drive. let the wheels spin and listen for noise. just make sure it is secure so that you dont cause more damage. duh.
Old May 13, 2007 | 09:14 PM
NJMandCEM's Avatar
NJMandCEM
Or... What you can do... is just jack it up spin each wheel by hand... then you'll know which corner has you problem...
