Dealer says dont use synthetic Oil????
Old May 22, 2007 | 08:15 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: Dealer says dont use synthetic Oil????
You've got to be kidding!!!!
As far as the filter goes, Mobil1 or WIX all the way, smaller micron, better built filters. I use an M1-301 on mine--the 1-quart size. Synthetic of almost any kind far surpasses virtually any consumer available dino oil out there. I personally use Amzoil in mine, but Mobil, Royal Purple and the others are great too.
No, you don't have to flush the system either, just change like normal and you're good to go. I change mine every 6k miles with a filter change at 3k. Currently have 52K on mine and it still runs like new.
ORIGINAL: go49ers
Hello
I have a 2006 Ram 1500 Hemi and I was thinking of using Synthetic Oil (Royal Purple or Amsoil) but my dealer said that Dodge doesnt suggest using synthetic. Has anyone heard of such a thing? They said to use a regular 5w20 oil instead. Thoughts? Also any recomendations on a good oil filter?
Thanks
Matt
Old May 22, 2007 | 11:21 PM
cyclone429's Avatar
cyclone429
Best to break your engine in with dino oil before going to synthetic, That's what my Dodge dealer told me, Dodge dealers will not lose money servicing, they carry synthetic oil as well as dino oil and are more than happy to have you pay extra.
I switched to mobile one, and my truck runs a lot better, you don't gain any extra time betwean oil changes, you still have to check your oil to see if it's dirty and decide not by the owners manual, but the condition of your oil.
The Ram SRT needs synthetic oil, so how is synthetic going to harm or viod warenty covergae, just make sure you use 5/20.
Old May 23, 2007 | 12:33 AM
FFMedic1479's Avatar
FFMedic1479
ORIGINAL: cyclone429
I thought that you had to keep the oil in (barring the condition of the oil, I'm not so dumb as to leave the oil in if it looks like ****) for the time frame recommended (such as 7500 or whatever) because of the how the protection is not constant, and improves during use (kinda like a curve on the graph, the worst at both ends and the best in the middle).
Old May 23, 2007 | 01:39 AM
JimmyDiablo's Avatar
JimmyDiablo
I like napa gold filters, and mobil 1 when I had my hemi.
Old May 23, 2007 | 01:56 AM
master tech's Avatar
master tech
Site Moderator & Tech
Dodge viper use 0/40 mobil oil and the P/T turbro use 10/30 mobil, so as long its 5/20w then it shouldn't be a problem. Mobil oil is synthetic, and I'll bet your dealer sell it over the counter. And so I don't leave out the crossfire lovers, Mobil oil too.
Old May 23, 2007 | 10:01 AM
abarmby's Avatar
abarmby
go49ers
When you change your oil, cut into half or thereabouts,a 2 or 3 liter soft drink bottle.
With the screw cap downover, slide it over your oil filter after you have loosened it slightly.
Then push the bottle all the way up your filter and continue to unscrew the filter off.
As the filter comes away from the engine block, the old oil in the filter will be caught in the pop bottle and not dribble all down your arm and onto your drive.[:@]
You can then undo the screw cap from the pop bottle and drain the waste into a suitable container.
No mess and all nicely done.
Hope this helps?
Al.
Old May 23, 2007 | 02:39 PM
go49ers's Avatar
go49ers
Thats a great idea thanks for the post!
Old May 23, 2007 | 02:52 PM
speeddemon145's Avatar
speeddemon145
That soft drink bottle is a great idea oil always gets all over the rack as its right under the filter this will make that a thing of the past.
Old May 23, 2007 | 05:10 PM
mdram43's Avatar
mdram43
mobil 1. every upper end, sports car, etc all recommend it
Old May 24, 2007 | 04:43 AM
Powerubi Wacon's Avatar
Powerubi Wacon
I have been using Mobil 1 synthetic for over a year and a half now in my Dodge without any issues. I use a Wix filter exclusively. I have used Mobil 1 for about ten years now; in a Toyota truck and three Jeeps, and never had a problem.
