gears
Old May 25, 2007 | 04:35 PM
greengo's Avatar
greengo
Default gears
ok. this is a question for the truckes/ people that have put 4.56 in the pigs. what tire size are you running. i've got an 03 hemi 4x4 with aem brute force, bankes monster exhaust, tb spacer, 315-70-17 bfjunck, and the stock 3.55. i was thinking of putting in 4.10. not sure though.
Old May 25, 2007 | 07:10 PM
helopilot's Avatar
helopilot
Default RE: gears
I have 4.56's and 30" tall 295/50/20's.
Old May 25, 2007 | 08:40 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: gears
definately go with the 4.56 gears since your running a 35" tire
Old May 25, 2007 | 10:23 PM
kenihemi's Avatar
kenihemi
Default RE: gears
I have the stock 20's with 33" diameter tires and have the 4.56 gears.
Would have went with 4.88's if somebody made them from the 8" front diff. Sigh.
Old May 26, 2007 | 12:07 AM
greengo's Avatar
greengo
Default RE: gears
i don't want to sound like a dumb a$$ but before i make a $600.+ investment i want to make sure it is a correct 1. i just would like to see tire size to gear ratio. i plan on building a custom lift of built upper &lower control arms with coil overs and maybe even bigger tires for trail use. please lets get more feed back. some one else is thinking the same as me.[8D]the 6.1 cam is coming soon also. it is also a quad cab. my 4 yr old loves offraoding.
Old May 26, 2007 | 12:19 AM
djr04's Avatar
djr04
Default RE: gears
I would say go 4.56's. The rams with stock 20's come with 3.92 rear ends, and those tires are shorter than the ones you are going to be putting on (275/60R20 which is 33" versus your ~34.5" tire). Also, I don't recall hearing of anyone wishing they had went 4.10's instead of 4.56's, but I have heard people wish they would have installed 4.56's instead of 4.10's
Old May 26, 2007 | 12:21 AM
helopilot's Avatar
helopilot
Default RE: gears
ORIGINAL: greengo
Here ya go, you can email me for the actual file if you want to play around with formulas
