rear differential question
Old May 25, 2007 | 09:17 PM
lvlud_on_the_tires's Avatar
lvlud_on_the_tires
Default rear differential question
ok i have an 05 ram 1500 slt quad cab. i love the truck but this past week its been sounding like the rear end is loose and shaky and the transmission gears are grinding. well the dealership where i bought the truck isn't a dodge dealership but i have an extended warranty with them. well one of the mechanics told me he had the same problem and all it was to get fixed was to get the differntial fluid changed and a dodge synthetic added to it. anybody else ever heard of this?
Old May 25, 2007 | 09:23 PM
djr04's Avatar
djr04
Default RE: rear differential question
It is possible that if your rear diff has the lsd without additive that you would notice grinding and noise. It is also possible that if you have the lsd, a clip broke and it is spinning around in your gears. Could be other things as well, hard to tell without seeing the actual vehicle. When they change the fluid they will be able to check out the differential for any other problems anyway.
Old May 25, 2007 | 10:18 PM
kenihemi's Avatar
kenihemi
The additive will only affect turns.
Old May 26, 2007 | 11:31 AM
HankL's Avatar
HankL
All Ram 1500 owners have been hoping that Chrysler has solved the high failure rate of the 9.25 differential, but posts like these keep coming up on forums.
Pinion bearing, pinion seals,
and attachment clips inside the NoSpin
all have been trouble spots as far back as 1995
Old May 26, 2007 | 02:24 PM
CarGuyOhio's Avatar
CarGuyOhio
Your differential came with syn from the factory.
Also, note that service is 15K, change at 15K.
