LED PROJECTOR HEAD LIGHTS
Old May 25, 2007 | 10:52 PM
opa889's Avatar
opa889
Default LED PROJECTOR HEAD LIGHTS
I just bought a set of"LED PROJECTORHEAD LIGHTS" for my 2004 Ram, however I have hit a big installation pronlem. The orange marker light/turn signal work fine, the stock head light is removed and the new lights have 2 different bulbs, on of these bulbs works fine the other one not at all. Plusthere are several LED wires that I haven'tgot a clue how to hook up.
Old May 25, 2007 | 11:35 PM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
Default RE: LED PROJECTOR HEAD LIGHTS
You need to hook the LED wires into either a source that turns on with the key or your parking lights. As far as your other issue, I have no answer.
Old May 26, 2007 | 04:06 PM
NJMandCEM's Avatar
NJMandCEM
Did'nt come with directions???... if not calll the seller and ask...
Old May 26, 2007 | 09:22 PM
kenihemi's Avatar
kenihemi
The new lights should use the stock plugin connectors for the high/low and the leds have 2 wires each, usually one black, one white.
Put them together and splice the black into ground, the whites get spliced into your parking lamp wires
Contact me with any questions..
