How many miles on your HEMI?
Old Nov 12, 2015 | 04:56 PM
  #111
nibroc's Avatar
nibroc
Old Nov 14, 2015 | 05:43 PM
  #112
Will_V2Lab's Avatar
Will_V2Lab
04 1500, 97000 miles. Had trouble with a lifter, everything else is bulletproof. Not a single drop of oil underneath the engine and trans.
Old Nov 23, 2015 | 02:34 PM
  #113
fishfiz's Avatar
fishfiz
My 08 2500, just turned 257,000 miles. Have had no repairs
Old Nov 23, 2015 | 09:57 PM
  #114
My360's Avatar
My360
I dunno bout miles but I got 600k kilometres on my '05. Still runs strong
Old Nov 28, 2015 | 01:24 AM
  #115
rought's Avatar
rought
04..5.7 hemi.. 217,000 all city miles..have done nothing to motor but plugs,air filter and oil change every 6,000 with a "filter change only" at 3,000 ..Mobil 1 .. doesn’t burn a drop of oil between changes.. oil comes out almost the same color it was when I put it in…runs like it did new with no ticking.. ran a compression check all cylinders came out between 150 and 155lbs.. added oil to cylinders and it had no change..
Old Nov 28, 2015 | 10:29 PM
  #116
beech2000's Avatar
beech2000
I'm at 291K on my 03 2500. valve springs changed at 273K. All else was routine maintenance. On third set of tires. 50/50 city/hwy
Old Nov 30, 2015 | 04:19 PM
  #117
HemiManSam's Avatar
HemiManSam
My 2007 1500 has 172,000.I have loved every mile so far. This truck pulls a 7000 pound trailer 8 months a year. Just put 2500 coil springs and aftermarket shocks and a spacer, as well as a 5 Leaf Heavy Duty leaf spring set and aftermarket coilover conversion. Best investment so far.
Old Dec 2, 2015 | 04:27 PM
  #118
olred4x4's Avatar
olred4x4
I just purchased a 2008 with 234000 miles on it, wanted a 4x4 for winter, and it runs fine. The individual stated hes never changed the plugs, doing that this weekend. If its true, thats pretty impressive!
Old Dec 2, 2015 | 08:08 PM
  #119
uponone's Avatar
uponone
^^olred...it might be true. I have a 2003 with 215k on it. I changed the plugs at 100k...I THOUGHT. I just recently learned there were two plugs in each cylinder. One of my coil packs was shorting out and jumping a spark so I went to chang the pack and HEY, theres a plug under there! Come to learn, the plug under the pack does most of the work, the other plug is just for burning excess gas. So I changed all my coils, plugs, and wires. Check out the picture of a 13yr old plug with 215k on it:
Old Dec 2, 2015 | 08:21 PM
  #120
olred4x4's Avatar
olred4x4
Default Not bad!
That doesn't look to bad for that many miles! I assume you didn't have any issues removing it? My concern is buildup and/or the plug is seized.
