How many miles on your HEMI?
  #121
Old 12-03-2015, 02:34 PM
uponone's Avatar
uponone
uponone is offline
Originally Posted by olred4x4
That doesn't look to bad for that many miles! I assume you didn't have any issues removing it? My concern is buildup and/or the plug is seized.
No problems at all removing them. I got the engine hot and went to work...they all came out smooth. A buddy with a ford put a good scar into me about fords problems with plugs breaking off. He told me to crack the plug and spray some carb cleaner into the hole and let the heat suck it into the cylinder...cleaning all the carbon off the threads. He did this on his truck and still broke 4 plugs.
I DID NOT use this method. I just simply unscrewed them without any issues. I did put 'never-seize' on the ones going in.
  #122
Old 07-07-2016, 10:12 PM
stev's Avatar
stev
stev is offline
2003 2500 5.7L Hemi ... 110,0xx at the present time.
  #123
Old 07-07-2016, 11:00 PM
66three83's Avatar
66three83
66three83 is offline
2006 Mega Cab 5.7 Hemi, 230,000 Miles. Original Engine and Trans.
  #124
Old 07-08-2016, 07:31 AM
olred4x4's Avatar
olred4x4
olred4x4 is offline
Default 2008 Mega Cab
I purchased mine with 242,000 miles. The guy never changed the spark plugs. I did this and an oil change and changed two of the o2 sensors and it runs great!
  #125
Old 08-08-2016, 07:59 AM
cuconwk's Avatar
cuconwk
cuconwk is offline
Default 2011 3rd D Citadel
156,897 miles on my HEMI! Replaced the WaterPump at 144k and Brake Master Cylinder at 132k. Both i think only went because of Dealer Mech's in PA SU*K
  #126
Old 08-08-2016, 10:56 PM
stev's Avatar
stev
stev is offline
ZOINKS !
I just change the plugs at 111,5xx and thought that was an amazing feat for the plugs going that long.
Hope you got the truck at a great price. I did find that changing the driver side plugs, if a person is skinny enough, you can place your foot on the frame right behind the cooling fan and strattle the hood cross-member. It helped greatly.
The plug changing wasn't hard, just those 10mm screw holding the COP took the longest.
  #127
Old 08-09-2016, 05:01 PM
Gone Fishin's Avatar
Gone Fishin
Gone Fishin is offline
232000 still original, exept plugs, wires, antifreeze, drive belt (changed to gatorback over 100K ago) general consumables, and clutch, bad pilot bearing shortly out of warranty
  #128
Old 08-12-2016, 01:54 PM
dtp220's Avatar
dtp220
dtp220 is offline
Mine is 2005 RAM 1500 ST V6 3.7L with regular good maintenance records, and just past 145000 mile.
History of replacements: radiator fan, water pump & belt, suspension sets (left, right, upper, lower) 1 year ago, fuel filter and pump combo 2 months ago.
It is still going strong
  #129
Old 08-17-2016, 12:09 AM
KasperR34's Avatar
KasperR34
KasperR34 is offline
Man, I'm only at 97k, bought her March 24th of 2011 with 58k. As for replacements, well:
Just look
  #130
Old 08-17-2016, 01:45 AM
Chet Ubetcha's Avatar
Chet Ubetcha
Chet Ubetcha is offline
3rd Gen Ram Moderator
Bought new in 2005. Just turned 90,600 today.
I said when I bought it that if I turned 100K on it, I'd feel I got my money's worth. I'm nearing that milestone, and I think there's many, many more miles left in it. I don't see myself getting rid of it. If something does go wrong, I'd rather spend $500, $1,000, etc. once than $500 a month for the next several years just for a warranty that will run out halfway through the payments.
Quick Reply: How many miles on your HEMI?
