Hemi - Upgrade from single exhaust pipe
Old Sep 20, 2004 | 02:50 AM
jb111's Avatar
jb111
Default Hemi - Upgrade from single exhaust pipe
Hi All. I've enjoyed my Hemi for 3 months now and am thinking of installing a dual exhaust. Are there any benefits (other than the ferocious roar)? Does anyone have any recommendations on a brand?
Thanks,
JB111
Old Sep 20, 2004 | 10:31 AM
Beastmaker's Avatar
Beastmaker
Default RE: Hemi - Upgrade from single exhaust pipe
[:'(]search the forums here - there's a bunch of posts in here about that
Old Sep 21, 2004 | 10:46 PM
jb111's Avatar
jb111
Not sure if my reply worked...Thanks Beast
Old Sep 21, 2004 | 11:52 PM
Beastmaker's Avatar
Beastmaker
JB111 - Here's a few link to some of them.
https://dodgeforum.com/tm.asp?m=77167
https://dodgeforum.com/tm.asp?m=79913
https://dodgeforum.com/tm.asp?m=75180
https://dodgeforum.com/tm.asp?m=71942
https://dodgeforum.com/tm.asp?m=73089
https://dodgeforum.com/tm.asp?m=72123
Old Sep 21, 2004 | 11:55 PM
drtelco's Avatar
drtelco
Dual exhaust will actually lower your performance. You'll make more noise, but will be slower. If you want a better sound run a set of JBA ceramic headers then a exhaust of your choice, flowmaster, etc.
Old Sep 22, 2004 | 12:58 AM
356MAGNUM's Avatar
356MAGNUM
If you are doing a true dual system vs cat-back, to prevent the loss of power, you need to od headers, H-pipe(very important) and dual cats(to be legal). If you do the out, then you need to do the In. Cold Air Intake(CAI). More air means more fuel(bigger throttle body). Bigger TB/fuel more $$. Now if you change tire size drastically, you will need to change gears. Now since everyting in the trucks are computerized, need to reprogram the PCM more $$$. Talk about an domino effect. You can spend an easy $2000 for, i would take a guess 50-75hp and sh*tty gas milage. More and more I think about it, it's just not worth it. Granted the flowmaster upgrade I did to my EX ram gave it a respectable sound and a lil boost in power. It only cost $300. Sorry about the rambling. It all depends on if you have more dollars than sense hahaa(joking).
Exhaust
headers
pipes alteast 500
throttle body 250
CAI 200
Programmer 400
Lift kit 1500
Tires 800
rims 800
gears 200
total 4650
Old Sep 25, 2004 | 02:49 PM
OutSider's Avatar
OutSider
well, i dont know about ya'll, but we had Flowmaster original 40's with a 1 in 2 out system on our hemi single cab, and it boosted our mpg up to 17 from the usual 14, and it has a definate performance increase. we used 2 1/2 inch tubing on it, and absolutly love it. the truck also has a K&N cold air intake kit on it also, but that was installed 3 months earlier than the exhaust.
Old Sep 25, 2004 | 07:27 PM
Beastmaker's Avatar
Beastmaker
EXACTLY Outsider, Since I put my Flowmaster 1 in 2 out, I increased my MPG too. Now I have to work at NOT breaking the tires loose, especially if it's cold. The sound is a little loud inside (i have no kids - and the wife drives her own car), but it does sound pretty sweet.
