where did you ground your amp?
Old Jun 1, 2007 | 08:34 PM
HuntinHanson's Avatar
HuntinHanson
Default where did you ground your amp?
Im getting my amp wired in but having some difficulty finding a good spot to ground it. I'm mounting it underneath my back seat. any suggestions?
Old Jun 1, 2007 | 08:49 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: where did you ground your amp?
You should be able to mount it to any screw/bolt on the frame of the seat.
Old Jun 1, 2007 | 09:00 PM
Ben D.'s Avatar
Ben D.
^^^ Yup just make sure there is no paint aroudn the bolt so you get a good connection and since the bolts running through the floor are connected to basically the entire truck it makes a great ground.
Old Jun 1, 2007 | 09:04 PM
squirtbottle09's Avatar
squirtbottle09
Just sand the paint off and use the seat mounts. That is where it was grounded in my last truck.
Old Jun 1, 2007 | 09:32 PM
nuttyprofessor's Avatar
nuttyprofessor
Agree with above....make sure you use a wire wheel,sandpaper, or anything else to ensure that you are grounding to metal and you will be fine. If you have the non fold flat rear seat there is a "stud" sticking up....a 7/16" nut will fit it.
Old Jun 1, 2007 | 09:36 PM
austin's Avatar
austin
Actually I used the seat when I grounded my amps. It worked for one, then it stopped for the higher power amp! So I had to relocate it to the actual frame. If you pull up the door sill, lift up the carpet, right there in front of your face is a good place also. Took it to Circuit City, and that is how they do it also. I would take a pic if I could, but I still can't walk(had surgery on my ACL and meniscus). But yes apparently that is better than the seat bolt(and yes, I did take off the paint!
Old Jun 1, 2007 | 09:54 PM
Horseapples's Avatar
Horseapples
Quick!! Pull my finger!! [sm=guilty.gif][sm=icon_guiness.gif]
Old Jun 3, 2007 | 03:44 PM
HuntinHanson
OK i ended up pulling teh bolt out of the crossmember for the seat, sanding it down really really good and putting it in there. Everything works great now!
Old Jun 3, 2007 | 06:33 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Glad you got her working.
Old Jun 3, 2007 | 07:58 PM
HuntinHanson
hhaha yeah me too i get seriously pissed when something doesnt work. Its like an obsession trying to get it to work too
