CAI installed and now Cruise control won't work
Old Jun 16, 2007 | 03:53 AM
PinkTacoLover's Avatar
PinkTacoLover
Default CAI installed and now Cruise control won't work
I installed the AEM Brute Force on my baby and all I gotta say is damn!!! Response is great, sounds great. Coupled with my exhaust I'd say I've got a nice setup so far. My machine is breathing real good now. The only problem is now, for some reason the Cruise Control doesn't work anymore. Cruise control will not turn on. I set everything back and connected everything properly. The only thing that I did differently was to TRY and reset the ECM/PCM but it didn't work right. I took out the fuse from cavity 23, didn't hear the beeping sound you're supposed to hear when you try to start the engine, then I put the fuse back in. Any thoughts and ideas on the cruise control?
Old Jun 16, 2007 | 10:52 AM
PinkTacoLover
Default RE: CAI installed and now Cruise control won't work
I figured it out. There's this bag *** electrical connection on the throttle body that has a switch on it. Nothing that says on or off. Anyway, I toggled it one way and after I did the cruise control worked. Ok, in case anybody every has a problem this is one of the things that you can try to resolve your issue.
Old Jun 16, 2007 | 12:10 PM
white26golf's Avatar
white26golf
could you post a pic of the brute force installed?
Old Jun 16, 2007 | 02:40 PM
PinkTacoLover
I will post a pic up soon. It looks pretty tight IMHO.
Old Jun 16, 2007 | 05:18 PM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
Here's mine on a 2004 4.7L
[IMG]local://upfiles/63182/37F3B694354A492ABD71730C53B9C89D.jpg[/IMG]
