Moisture in headlight
Old Jun 21, 2007 | 03:33 PM
ut's Avatar
ut
Default Moisture in headlight
I have moisture in one headlight on my 03 ram. What is the best way to repair this and keep it from happening again? Thanks.
Old Jun 21, 2007 | 04:19 PM
Pappy_FB's Avatar
Pappy_FB
Default RE: Moisture in headlight
I have a friend who has a 98 and moisture was in his HLs also. He was going to drill a hole in the bottom for drainage. I really don't reccommend this, a hole will let moisture in as well.
Do a search, I remember a post on how to remove the amber reflector in the HL and it gave directions on how to disassemble them. That would let you get out the water and then you could reseal it on rebuild.
Good luck to you.
Old Jun 21, 2007 | 04:47 PM
kregier's Avatar
kregier
This happened in the passenger HL of my '03. I took it out, put some water in it then tilted it at various angles to see where the moisture was getting in. Then I dried it out using a hair dryer (stuck it in one of the holes for the bulbs), and siliconed shut the source of the problem.
Old Jun 21, 2007 | 05:04 PM
bigjrussell's Avatar
bigjrussell
The headlight teardown was done by RobGL and it's in the 3rd gen DIY sticky at the top of the 3rd gen forum.
Old Jun 21, 2007 | 05:16 PM
eltupac's Avatar
eltupac
If this happened to me, I would tell my wife I need new headlights and buy projectors with HID, if she askes why I got those, I would tell her they are cheaper than OEM. They dont look that bad.
Old Jun 21, 2007 | 06:26 PM
Ricker's Avatar
Ricker
ORIGINAL: bigjrussell
Hey, where the heck is RobGL anyway? Did he leave? He was a cool dude.
Old Jun 25, 2007 | 04:19 PM
ut's Avatar
ut
Thanks for the help guys. I removed the headlight, rinsed it out, and dried it with a hairdryer thru bulb hole, then siliconed around the seam. Will see how that does. If it comes back I'll tear it apart.
Old Jun 25, 2007 | 04:41 PM
chopperzen's Avatar
chopperzen
wait til you hit another 3K miles and then change yer headlight fluid.
Old Jun 25, 2007 | 05:12 PM
Mopartoya's Avatar
Mopartoya
ORIGINAL: chopperzen
Yeah, don't fergit yer blinker fluid either!
Remember, need to add torque to the torque converter every 6k miles too!
