Drum Roll Please...180 T-Stat Install.....
Old 07-02-2007, 03:04 AM
FFMedic1479's Avatar
FFMedic1479
FFMedic1479 is offline
Default RE: Drum Roll Please...180 T-Stat Install.....
Nice job Pappy... very well documented. So... stop playin around... you obviously drove it, give us the skinny...
Old 07-02-2007, 03:09 AM
FFMedic1479
So... on the beer o' meter, what was the time it took to do the job.
Old 07-02-2007, 03:13 AM
Pappy_FB's Avatar
Pappy_FB
Pappy_FB is offline
ORIGINAL: FFMedic1479
I was freakin Hot, and I wanted to go test it so I had to keep it down to2 or under 20 mins.
Old 07-02-2007, 03:53 AM
FFMedic1479
Not bad...
The results Pappy... the results... you like playin your little games... its like you are playin just the tip or something... tease.
Old 07-02-2007, 04:00 AM
livetokite's Avatar
livetokite
livetokite is offline
nice seems simple the way you posted it.
jus curious what does this do to performance?
does it just help with the temp?
prolly a stupid question but oh well lol.
Old 07-02-2007, 12:51 PM
Pappy_FB's Avatar
Pappy_FB
Pappy_FB is offline
Ok....
After I got it installed I had to drive 12 minutes in Stop and Go traffic before I could stop and do a quick check on the Coolant Overflow tank. During this time the Temp got up to its old normal setting once, about 10 minutes in to the drive. The two minutes left before I got to a stopping point the Temp had dropped, I rekon this was the first time the new T-Stat had opened.
When I finally did stop, I checked the Coolant Overflow tank and it was still high. This worried me.
I got to do a little Highway driving after that 55 to 60 MPH for about 20 minutes. The Temp stayed at the New setting the whole time.
Once I got back into the neighborhood the temp started to rise a little, but never got anywhere close to the old Stock setting.
Back in the drive way I checked the Coolant Overflow tank again and it had Not Changed.
So I waited for the Truck to cool off and transferred the coolant from the Overflow back to the Radiator. I had to add about 8 ounces of Distilled Water to top it off.
I’m really not teasing you guys I just haven’t had time to go give her a thorough Unbiased Independent Scientific Test hehe.
Hopefully today I can get her on the road and run it a little harder and longer.
P.S. Our local law enforcement is out thick in preparation for the 4thbecause people have been shootin off Fireworks for two or three days already. So I might not get a chance to run her to awful hard.
Old 07-02-2007, 12:57 PM
Pappy_FB's Avatar
Pappy_FB
Pappy_FB is offline
So far
No Codes
No Leaks
One Error (Dropped bolt in catch bucket) LoL
Old 07-02-2007, 01:25 PM
jorswift's Avatar
jorswift
jorswift is offline
Where can you get a 180 T-STAT?
thanks.
Old 07-02-2007, 01:56 PM
Pappy_FB's Avatar
Pappy_FB
Pappy_FB is offline
ORIGINAL: jorswift
thanks.
Jorswift if you do a search on 180 Thermostat in the Ram 3rd gen only you will get a lot of good info
I got mine here
http://www.autotrucktoys.com/ram/JET-Performance-Dodge-Ram-Low-Temp-Thermostat-89-Up-P8047C1862.aspx
After donig someresearch on my own I found out that the new version Stant 180might be the magic bullet for the Hemi. But I had already ordered this one.
Old 07-02-2007, 01:59 PM
Pappy_FB's Avatar
Pappy_FB
Pappy_FB is offline
[sm=repost.gif]
For performance hereis a repost of a thread on 180 T-Stat in a Hemi (300C tho) and a dyno run.
http://www.300cforums.com/forums/performance-modifications/12299-dyno-tested-180-deg-t-stat-16rwhp.html
Quick Reply: Drum Roll Please...180 T-Stat Install.....
