Drum Roll Please...180 T-Stat Install.....
Old Oct 14, 2007 | 12:36 PM
  #71
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Default RE: Drum Roll Please...180 T-Stat Install.....
While I did not have any dyno results I noticed about 1mpg better off this setup. When using some mods like this a 1/2 mpg here 2 mpg there start adding up in the long run. With everything I have on my truck right now I get about 22mpg on the highway at 65mph, depending on grade and outside temps.
Old Oct 14, 2007 | 03:21 PM
  #72
Pappy_FB's Avatar
Pappy_FB
ORIGINAL: dieseldoc1
good description on install, will give it a go. 1 thing,the bleed hole is for filling the system,not for draining it. the bleed hole is to vent air from behind the therostat so the sensing bulb is in the coolant as it must be to operate properly. they won't open right on steam. clutch fans lock up somewhere over 210 degrees so ur not fighting the full force of the fan until then.
Actually the Bleed Hole is for letting air out of the system, so you can fillit (top itoff) before the systemreaches operating temp. Me thinks it is more to protect the heads/engin from hot spots, running low on coolant. However it does work both ways.
I find this about as useful as **** on a boar hog as it is slow as molasses. I just topped it off and added coolant as need.
Clutch fans do lock up at a specific temp, they canalso fail to lock up or lock up altogether if their magic mystery fluid stops working. So an e-fan is in my future.
Plus I like the cool aluminum “HEMI†radiator bar Hammer got with his.
Old Oct 14, 2007 | 03:53 PM
  #73
tdmopar59's Avatar
tdmopar59
i am surprised you gained mpg... i would think the opposite... you think it was worth it than?
Old Oct 14, 2007 | 05:04 PM
  #74
moparmutt's Avatar
moparmutt
ORIGINAL: tdmopar59
Me too. I always heard growing up, that carb motors run better cooler and fuel injection run better(better mpg) hotter.
Old Oct 14, 2007 | 08:24 PM
  #75
dieseldoc1's Avatar
dieseldoc1
engine temp was raised for emissions control mostly
Old Oct 15, 2007 | 10:34 PM
  #76
NYPANAMA42's Avatar
NYPANAMA42
Judging from the fact that the majority of you have Hemi's. I guess my question is this. Is this T-180 only for Hemi's?
And has anyone checked, to see what the long term effects will be with this install?
Old Oct 17, 2007 | 10:43 PM
  #77
NYPANAMA42's Avatar
NYPANAMA42
Does anyone have an answer to the above question??? Are the 180 degree thermostat for Hemi's only?
Old Oct 17, 2007 | 10:58 PM
  #78
tdmopar59's Avatar
tdmopar59
ORIGINAL: NYPANAMA42
you can get a 180 stat for any motor.... your font is awfully large...
Old Oct 18, 2007 | 10:39 AM
  #79
NYPANAMA42's Avatar
NYPANAMA42
Well, you know how it is for us old guys......... Funny thing thougn, it looked perfectly normal to me.
Old Feb 2, 2008 | 12:54 PM
  #80
tamuccmike's Avatar
tamuccmike
thank you so much pappy...worked like a charm...my fingers burn from having antifreeze on them...but seems like it's doing its job. My temp needle is at the exact same point as yours after the mod...but my gauge never reached the "old" normal op. temp....you're right, that bottom bolt is a bitch...turned a 15 minute job into a 40 minute job, gotta have the right tools....again, thank you so much for this post!
