Drum Roll Please...180 T-Stat Install.....
Old Jul 17, 2007 | 02:04 PM
  #61
go49ers's Avatar
go49ers
Default RE: Drum Roll Please...180 T-Stat Install.....
How does the 180 T-stat affect the fan? In other words is the fan set to come on at 195 degrees (Factory T-Stat) which means it would never come on because the truck stays at 180 now. Or does the fan kick on whenever the T-Stat opens to cool the engine down? Just curious because I know some programmers have an option to control the fan because you are running a lower T-Stat. Inquiring minds want to know.......
Old Jul 18, 2007 | 10:49 AM
  #62
Pappy_FB's Avatar
Pappy_FB
ORIGINAL: go49ers
The 180 t-stat has no effect on a stock belt driven fan.
The stock fan for my radiator is a mechanical clutch type attached to my water pump so it runs all the time. This stock fan is belt driven (continuous parasitic fan as it takes power away from your engine to provide cooling air flow)
Your AC condenser has an electric fan but is not part of the engine cooling system.
My neighbor had an e-fan installed on his Ram as part of his upgrade path to HP heaven.
TheE-Fan mod to your radiator cooling system removers the parasitic belt driven fan and replaces it with an electric fan and frees up a few more horses. The e-fan mod does allow you to adjust the temp of when the e-fan itself turns on. Me thinks it posta be set 10 degrees less than the t-stat. So for a 180 t-stat you would set yer e-fan to kick on at170. I could be wrong.
P.S.
E-fan is definitely going on Pappys list O mods
Hope this helps
Old Jul 18, 2007 | 11:11 AM
  #63
go49ers's Avatar
go49ers
Thanks Pappy that clears it up for me I appreciate the info.
Old Jul 18, 2007 | 12:01 PM
  #64
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
ORIGINAL: Pappy_FB
P.S.
Hope this helps
I can't wait for the contradictory post.
I'll just do it myself.
(disclaimer: I just googled this but didn read it)
http://www.aaroncake.net/rx-7/efanmyth.htm
Old Jul 18, 2007 | 07:22 PM
  #65
DeWalt378G's Avatar
DeWalt378G
ok, just put mine in today. i want to say it feels really good, but it's prolly my imagination. yall know, you do a mod, you're all excited, you test drive and you feel like you just got bigger *****. anyway, i was wondering if superchips would somehow prevent my cel light from coming on in this situation. i already had sc in and now i just did the stat.is it worth returningmy programming back to stock for a few days and see if it throws any codes with the new stat or should i just leave it alone?
Old Jul 18, 2007 | 08:44 PM
  #66
HammerZ71's Avatar
HammerZ71
ORIGINAL: Pappy_FB
P.S.
Hope this helps
You pretty much hit the nail right on the head Pappy, only thing I might add is that the stock, belt driven fan turns in direct relation to your RPM's, which is why you are much more prone to over-heating in city traffic or when 4-wheeling slowly such as rock climbing, when RPM's and consequently fan speed is low. An e-fan turns at the same high rate of speed whenever it is running.
BTW -- Props to Pappy for putting in MY Jet 180* thermostat this evening. I just got it last nite and was dying to put it in, but a pretty severe eye infection had me not feeling to good about messing with it myself (that, coupled with the fact I didn't think I could fit my huge meathooks down near that bottom bolt). He made it look easy, just like he'd done it before!!!
Old Jul 18, 2007 | 10:13 PM
  #67
Pappy_FB's Avatar
Pappy_FB
Yer welcome HammerZ71
DeWalt are you getting a code or worried you are going to get a code?
Etiher way it can't hurt to set her back to stock, then do a reset.
Sir Hardin Thicke that was to funny bro...
Old Jul 26, 2007 | 07:50 PM
  #68
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Just added mine this evening. I am driving a 4 hour trip to Hatteras on Saturday and I will post the results. Thnaks for the link Pappy and the intel, worked like a champ.
Old Oct 14, 2007 | 12:45 AM
  #69
dieseldoc1's Avatar
dieseldoc1
good description on install, will give it a go. 1 thing,the bleed hole is for filling the system,not for draining it. the bleed hole is to vent air from behind the therostat so the sensing bulb is in the coolant as it must be to operate properly. they won't open right on steam. clutch fans lock up somewhere over 210 degrees so ur not fighting the full force of the fan until then.
Old Oct 14, 2007 | 11:02 AM
  #70
tdmopar59's Avatar
tdmopar59
everyone is sayin they were gonna post results.. did anyone see a gain/loss in mpg, power, anything??
