Fog Lights for 2004 4x4 quad
Old Jul 3, 2007 | 03:52 PM
kaisayles's Avatar
kaisayles
Default Fog Lights for 2004 4x4 quad
My truck is pre wired for fog lights but still have the fake plastic vents covering the holes. Any recs on which lights to use? I saw some through Mopar but I don't need the entire kit. Also, I assume once conected to the wiring, they will function concurrently with the headlights? Thanks for the advice. Happy 4th.
Old Jul 3, 2007 | 04:21 PM
itsmejto's Avatar
itsmejto
Default RE: Fog Lights for 2004 4x4 quad
You might need the relay for those, in the fuse box, usually not installed if the lights are not there.
I wired mine as daytime running lights, so they are on all the time.
Definate night vision improvement too.
Ebay has the right ones, they need a "funny" bracket to mount them correctly.
Old Jul 3, 2007 | 05:57 PM
oefootball_70's Avatar
oefootball_70
you will need a new light switch, then its just plug and play.
Old Jul 3, 2007 | 05:59 PM
HuntinHanson's Avatar
HuntinHanson
i bought a mopar kit off ebay, it comes with the lights, the wiring to connect to the pre existing wiring and the new headlight switch with fog light feature. 15 minute install, looks factory. I think i paid just over $100
Old Jul 3, 2007 | 06:59 PM
bigjrussell's Avatar
bigjrussell
Yup, mine was the same case. Easiest install I've done so far.
Old Jul 3, 2007 | 09:34 PM
FFMedic1479's Avatar
FFMedic1479
I am pissed. I made the mistake of going through my local dealer, and the kit that they gave me (well, $180 isn't giving now is it) was supposed to be the part number "that my model and year of truck keeps coming back to". I knew I had the connection in the bumper and they argued with me that the kit I had to have was all new wiring, relays, etc. It was a seperate little switch to turn it on (I don't really mind because I can leave it on and it will just turn on with the headlight switch) that I had to drill my dash to install. So, you guys were just able to plug into this stock harness? I'm not so mad about the way I had to install it or the extra money, just the fact they argued with me about having a connection on the bumper and were kinda rude about it.
Old Jul 4, 2007 | 02:58 AM
HuntinHanson
yeah the kit i have plugged right into the harness attatched to the inside drivers side bumper.
