Cleaned MAF Sensor 4-5 MPG Better
Old 07-12-2007, 06:36 PM
pakaalbite's Avatar
pakaalbite
pakaalbite is offline
Default RE: Cleaned MAF Sensor 4-5 MPG Better
i was watching that same show and i was wondering if it worked. Thanks for the input
Old 07-12-2007, 09:44 PM
david0991's Avatar
david0991
david0991 is offline
pics of the sensor. I have 50223 miles on the truck. Its great tooling around town getting 14.1 MPG compared to 10.1 MPG before. The 15.9 MPG was going 65 MPH on rolling hills east of Denver CO.
The guy at Checkers said a new sensor runs ~ $265 and not to touch the blue probe when cleaning it.
[IMG]local://upfiles/45084/4872C8528B1B438AB7D1CBD6274A2FE4.jpg[/IMG]
[IMG]local://upfiles/45084/4C4A16A62FA7405F9977B20740E2C1D8.jpg[/IMG]
Old 07-12-2007, 10:25 PM
HuntinHanson's Avatar
HuntinHanson
HuntinHanson is offline
maybe it was theIAT sensor?
Old 07-12-2007, 10:38 PM
david0991's Avatar
david0991
See pics above.
Is the sensor's techincal nameMAF or IAF or IATor speed density for a Dodge?
All I know is a MPG miracle occurred.
The AutoWeek guy also said to charge $$ if you clean your buddiessensor.
Old 07-12-2007, 10:59 PM
Mattcmdr's Avatar
Mattcmdr
Mattcmdr is offline
Would all this apply to the 4.7L????
Old 07-12-2007, 11:06 PM
david0991's Avatar
david0991
I bet the 4.7 hasa sensor for air flow inbetween the air filter and throttle boby. The AutoWeek guy's demo wasnot for apickup truck (maybe a jeep ??), he said in general there is a air flow sensor in between the air filter and throttle body.
Old 07-12-2007, 11:36 PM
HuntinHanson
yeah i'm almost positive thats the IAT sensor
Old 07-12-2007, 11:49 PM
david0991's Avatar
david0991
Your right, the IAT (Intake Air Temperature) sensor is correct. What's a MAF between friends.
On page 6-24 of the Chilton Dodge PICK-UPS 2002-05 Repair Manual shows the same sensor for the HEMI infigure 8.2c
The 4.7 IAT is shown in figure 8.2b.
The 3.7 IAT is show in figure 8.2a
Old 07-12-2007, 11:59 PM
FFMedic1479's Avatar
FFMedic1479
FFMedic1479 is offline
I think it is worth a try... couldn't hurt, or could it?
Old 07-13-2007, 12:26 AM
david0991's Avatar
david0991
I thinka Dodge Dealer could do it for you.
But... Be careful with it. If you can't take the back off a watch to replace a batteryor can't afford a new IAT...then don't do it. As long as your remove it bytilting it toward you just enough to get it over the stop and rotate counter clockwise, disconnect the wiring, don't touch the probe, clean, reinstall clock wise andconnect wiring.
I let you in on what really went on during the cleaning. I removed the sensor, start to clean it with paper towel then sprayed WD40 on it, then I thought I should goto checkers and get MAF (IAT) cleaner. It worked out in the end for me. - Skip the paper towel and WD40, only use the CRC MAF cleaner and be sure not to touch the blue probe.
I am a repair hack but the MPG is real.
Quick Reply: Cleaned MAF Sensor 4-5 MPG Better
