led resistor
Old Jul 14, 2007 | 08:54 PM
turbot_bird's Avatar
turbot_bird
Default led resistor
hey guys, im istalling led bulbs in my moms 04 hemi, which wires do I install the resistors?
Old Jul 14, 2007 | 09:00 PM
turbot_bird
Default RE: led resistor
ok, so far all four rears are staying on constant
Old Jul 14, 2007 | 11:14 PM
turbot_bird
anyone have a wiring diagram for an 04 ram?
Old Jul 15, 2007 | 03:21 PM
chopperzen's Avatar
chopperzen
You should have 5 wires and you need to splice into the two that are running the LEDs. I think it was a black wire and the other was pink and green or white and green. The part that plugs into the light strip has two going in on one side and 3 on the other. one of the three is reverse. I think bottom. What kind of load equalizer did you get? I had some on my truck and when I went to a second pair of LEDs for my turn signals, I started blowin the fuse. I ended up taking them out..
Old Jul 15, 2007 | 11:42 PM
turbot_bird
I got the resistors that matched the led's. I replaced all 4 bulbs and put i resistor in the two wires like you said but the brake lights and turns still dont work right. no fuses blown yet though
Old Jul 16, 2007 | 12:17 AM
Night_Runner's Avatar
Night_Runner
i heard some led bulbs will light up but wont work right if plugged in 180 deg the wrong way....flip it 180 degrees and see if it works...i heard some are touchy like that...or am i thinking of hid's????
Old Jul 16, 2007 | 12:50 AM
turbot_bird
I already tried that.
Old Jul 16, 2007 | 02:17 PM
chopperzen's Avatar
chopperzen
Aight. I just took off my rear passenger side light. You are going to connect to the 1)black wire and the blue/white wire and 2) black wire and brown/red wire the two colored wires are the lights. I didn't check the driver's side, but they are configured the same way, but colored different besides the black. Look at where itplugs into the strip and they are the two top ones of the three on that side. The pic is from the Passside. Hope this helps
[IMG]local://upfiles/40079/D8BCE398EC814DD58432CB1CAC07D66A.jpg[/IMG]
Old Jul 16, 2007 | 06:11 PM
turbot_bird
yeap, went to dodge and had them print me out the diagram and studied it and came up with the same thing. thanks guys works great
Old Jul 16, 2007 | 10:44 PM
chopperzen's Avatar
chopperzen
no problem.
what kind of load eq did you get? What LEDs and how many in them?
