medium evap leak
Old Jul 14, 2007 | 10:12 PM
nastyram's Avatar
nastyram
Default medium evap leak
need help.02 4.7 code po442 medium evap leak,keeps coming up,check whole truck for vac leak nothing,had it smoke tested nothing,anyone ever come across this,if so please point me the right way.pulling my hair out.
Old Jul 14, 2007 | 11:26 PM
MexiRam's Avatar
MexiRam
Default RE: medium evap leak
not the medium leak but ive been getting the very small leak code three times already. taking it to the dealer next week.
Old Jul 15, 2007 | 09:32 AM
chadmech28's Avatar
chadmech28
If you have smoke test it and found nothing, Check your purge solenoid make sure it holds about 15hg of vaccum. If this is good check your gas cap more than likely the check valve is stuck and you will have to replace it. If you don't find anything else I would just replace the cap. This is a pretty common thing on Dodge.
Old Jul 16, 2007 | 08:26 PM
nastyram's Avatar
nastyram
thanks for the infor guys,put new gas cap on today have to see what happens,thanks again
