Towing shocks...???
Old Jul 24, 2007 | 06:36 PM
Silver Doug's Avatar
Silver Doug
Default Towing shocks...???
Does Dodge make towing shocks..?? I've got the 2007 5.7L, 4X4, Qcab, 1500, And when towing our 5200lb trailer the backend at times wants to move up and down as the trailer does..not a lot but some... I thought that stiffer shocks would help...??? any Ideas...??? Doug
Old Jul 24, 2007 | 07:05 PM
Mean Max's Avatar
Mean Max
Default RE: Towing shocks...???
I think that the factory shocks are of decent quality, and really stiff ones may make it ride too rough when not towing.
Maybe some air springs may help, without sacrificing you ride quality?
I was just wondering, have you verified your trailer'stongue weight?
Old Jul 24, 2007 | 07:43 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Maybe a weight distributing hitch might help... keep everything a little mor stable anyways...
Old Jul 24, 2007 | 08:12 PM
scoose's Avatar
scoose
Ditto ^^^^^^^^
Old Jul 24, 2007 | 08:44 PM
Silver Doug
I've got the 10,000 lb. Equal-I-zer hitch ...and the tounge wt. Is 524Lbs. Just what are air springs... and how are they attached...around the shocks...??? Doug
Old Jul 24, 2007 | 08:49 PM
Mean Max's Avatar
Mean Max
ORIGINAL: Silver Doug
Look at these Doug.
http://www.truckspring.com/VSearchResults2.aspx?cID=741
Old Jul 24, 2007 | 11:10 PM
John  M's Avatar
John M
I had some $25 "helper springs" from AutoZone on my last truck (92 GMC) and they made a huge difference in how tight the back end was. They really reduced the amount the rear sagged when weight was applied and also made it handle better unloaded.
Old Jul 25, 2007 | 01:12 AM
sa1765's Avatar
sa1765
i disagree about the stock shocks...they are crap, even for regular driving...they have no rebound dampening.
i like the rancho 9000's...gives me some adjustability for heavy or no load and they actually work. i also just bought some timbren overload springs but haven't had a load in the truck yet to decide if they work worth a ****, but as soon as i know i'll post.
as far as your original question, get some sort of overload/helper springs and some better, if not adjustable, shocks.
Old Jul 25, 2007 | 11:16 AM
HuntinHanson's Avatar
HuntinHanson
I'd try some air bags or maybe even the rancho 9000 shocks. They have a 9 position dial to adjust the stiffness. You could crank it up when towing and soften it up when your not
Old Jul 25, 2007 | 04:29 PM
Mean Max's Avatar
Mean Max
ORIGINAL: sa1765
I'm sure that you have a reason for not liking your stock shocks. Historically, stock shockshave been****ty on almost every vehicle made. But my '06 has felt like it has had really good rebound & compression damping (much to my surprise!) in the past 22K miles since new.
Would it be possible that there has been some kind of spec or build change since '04, orsomewhere along the line?
