3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Dodge builds all 5.7L Hemi's on the "Same" Line which means they are the same engine. They have said the only difference between the non-MDS and MDS are the 2-piece MDS cylinder-deactivating lifters.
I bet the PCM code/program is different too boot
You're correct. I just didn't add that. They use a different program on every different model.
