Electric cutout problems
i installed my electric cutout about 2 months ago now and i went to open it the other day but it wont open, if u get someone to hold the switch to the opening position then crawl under and give it a little push it opens... has anyone had a problem like this befoer?
Try some lithium grease spray or tube. This will work better against the heat. WD-40 is water based and depending on what is actually sprayed can possibly rust any moving parts. If you use WD-40, you will have to use it all the time to keep the rusting and seizing from happening.
ORIGINAL: L and R Two
You are correct on this, however when WD-40 is exposed to extensive heat, the lubricant breaks down and forms almost a rust like substance build up in tight spots.
I belive it...
Trending Topics
Yep I stink we are all in agreement it is binding.
WD-40 and lithium grease are great lubricants.
Might I suggest a dry graphite lubricant?
Good up to about5400 degrees F (3000 C)
However it is conductive so don’t get it on the electrical parts.
My 2 cents
My 2 cents
hey thanx guys i got a ton of wd-40 so ill try spraying some of that on there tonight and see what happens, hopefully that fixes it up. Cause i miss having it be able to work at the touch of a button haha
Depending on how long you've had them installd they may just have a little bit of carbon or mudbuilt up on them. Maybe time for a little cleaning, judging by yourpic. anyway..
