Trany drain plug ?
Old Aug 1, 2007 | 10:54 PM
marv02's Avatar
marv02
Default Trany drain plug ?
Anyone I getting ready to change out my trany fluid out with some AMSOIL Full Synthetic ATF I have the 6 Speed mauaul Trans in a 2006 Ram 1500.
When I get under the truck there looks like theres more than one low point that could be the drain plug which one do you use ? and which bolt is the fill plug .
Oh yea the trans holds 3 Qaurts of ATF+4 or a full Syntthetic like AMSOIL I read Red Line is good stuff also I read Mixed feeling about Royal Purple I going to stick with oil that I Know is good stuff.
Stock AFT+4 is 80% Synthetic 20% dino oil.
Mobil1 is good stuff and about the same price as AMSOIL I just Like AMSOIL they always done me good.
The Rear end takes 3 Quarts of 75-140 Gear oil Ialso running AMSOIL.
Old Aug 2, 2007 | 07:46 AM
Wishbone's Avatar
Wishbone
Default RE: Trany drain plug ?
1. Raise and support vehicle.
2. Remove drain plug (1) on transmission (2) and drain fluid.
3. Install drain plug and tighten to 50 N·m (37 ft. lbs.).
4. Remove fill plug (1) from side of transmission (2).
5. Fill transmission even with the bottom of the fill hole.
6. Install fill plug and tighten to 50 N·m (37 ft. lbs.).
Old Aug 2, 2007 | 08:26 AM
marv02's Avatar
marv02
Thanks for the info.
