how much did you pay for your turbo system installed?
Is there any realistic chance of running a turbo in a leased vehicle withouthavingDEALERSHIP/WARRENTYissues? It would be nice to hear something for a reliable source.
You can alter it in the lease. Mine was a lease but I've recently purchased it when my lease was over. You'll have to remove everything if you turned it back in or probably get dinged.
I was SO close to converting mine to a twin setup just to say I had one. I knew the power levels I run would be benefitted in a twin setup. So it was just for "talk". lol.
The stock engine will be fine IF and ONLY if you stick to a maximum of 7 psi. Some have run years at 8.5 to 9 but some have failed. Stick with 7 max and you should be fine with a good tune.
...The stock engine will be fine IF and ONLY if you stick to a maximum of 7 psi. Some have run years at 8.5 to 9 but some have failed. Stick with 7 max and you should be fine with a good tune. ...
Thanks
Thanks
Uh, Ben.
Grow up, know what you are talking about or go home.. First of all, twins on a stock/almost stock hemi will not spool faster, so you are wrong.
Second, he never said he has a built engine.
I don't care who doesn't buy a turbo from me, but the ones that do get a ton of support to get them right.
You probably don't have a turbo, you have no idea what is involved, but you needed to shoot off your mouth like you are the godfather here or something.
Then you go and compare a hemi truck to a viper, get real, twin turbos or not, LOL!
Psshh shut up kenihemi and hemifever, you guys don't know anything about turbos. These HEMI motors could handle 4 turbos if I wanted too. Everyone knows these motors are super strong and will not break. The transmissions could also handle all this power. I'm going to get some super sweet twins and do roll races in over drive all the time letting it shift into 2nd prime under full wot. These things are bullet proof.
Actually, with the questions I have seen you answer kenihemi and the way you conduct your self if I was ever to leave the N/A world I would contact you for a SINGLE turbo. I think the issue is that most the guys on here don't get the technical aspect of the hemi ram as much as this site really isn't as tech oriented as other forums for the hemi ram. Don't get me wrong, I enjoy this website as my post count shows that but you don't have all the sub 14 second trucks on here, the sharadon guys or any of the other hemi gurus that the other boards posses.
Sometimes I wish I didn't know what I was doing with hemi's and turbo's. Would save me hours of weekly phone calls helping folks and would probably make the wife happier. lol.
