electrolysis
Old Aug 7, 2007 | 12:10 AM
kx250frider617's Avatar
kx250frider617
Default electrolysis
What is it and is it harmful to the engine. Please explain.
Old Aug 7, 2007 | 12:31 AM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: electrolysis
I thought that was a technical name for shock therapy.... ya know... the thing they give crazy people when they don't stop blabbin...
Old Aug 7, 2007 | 12:45 AM
kx250frider617
No i was hearing that its somthing that happens when your cooling system isnt maintained.
Old Aug 7, 2007 | 12:50 AM
07 Ram TRX4
Here's the Definition....
http://www.google.com/search?sourcei...a+electrolysis
I have never heard it associated with coolant... and i thgouth that not maintaining your cooling system was just called "dumb"?....
Old Aug 7, 2007 | 12:54 AM
kx250frider617
how about this
http://www.4s.com/fourseasons/tech_t...rolysis_02.pdf
Old Jan 18, 2008 | 11:29 PM
CajunDreamer's Avatar
CajunDreamer
I purchased a 2000 Dodge Ram 1500 with the 5.9/360 a month ago and after the first week i started to smell antifreez well after exploring for the leak i found one of the freez plugs was leaking very badly so i changed the leaking freezplug, then i find out from a friend about electrolysis could be in the water system, well guess what? a few days after repairing the freezplug the water pump goes out, found it to be all ate up from electrolysis, changed the pump, few days after that i noticed water comming from the frunt of the motor, found that the thermastat housing was all eaten up as well, so i repaired all that and now waiting on the radiator and heater core to fail i did contact my local dodge dealer on the mater and one of the machanics told me that they found after a good flushing of the system to use DISTILLED WATER in the coolant system, he says they found this to help or solve the electrolysis problem so xing fingers and we'll see. but yes electrolysis can harm your motor and your wallet
Old Jan 18, 2008 | 11:31 PM
oefootball_70's Avatar
oefootball_70
ORIGINAL: 07 Ram TRX4
+1
Old Jan 19, 2008 | 08:12 AM
manogmin's Avatar
manogmin
so if there is current running thru the coolant, doesn't that mean that the block and other parts are not grounded properly, and what would be done to fix it. distilled water may work because it is filtered and there is nothing in the water to polarize, but the damage is done, and irreparable, so replacement, hmmm... that sounds nasty.
