help ASAP passenger window not working
Old Aug 10, 2007 | 02:03 PM
mdram43's Avatar
mdram43
Default help ASAP passenger window not working
passenger window and power door locks are not working. the driver side window works fine, passenger side does not move at all. the power door locks unlock but do not lock. anyone have any ideas?
Old Aug 10, 2007 | 04:01 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: help ASAP passenger window not working
Sounds like a wire harness (probably near the door hinges area) were cut somehow. You are talking about 3 separate circuits and only one is working now. Couple of questions need to be asked. 1) Can you operate any of the functions from the drivers side panel? 2) Can you lock/unlock useing the key FOB? 3) With either method, can you here the locks trying to work or the window trying to work? With the locks, you should hear the solenoid trying to pop and with the window, you will here a hum. This would tell you that you at least know there is power going to the items.
