Grinding noise in '02 1500 4x4
Old Aug 13, 2007 | 09:11 PM
Seanutz's Avatar
Seanutz
Default Grinding noise in '02 1500 4x4
I have a 2002 Dodge Ram 1500 4x4 with 85000 miles on it...just turned 85000 about two hours ago....anyways heres the story...
So today i was driving down the road and i started hearing a real bad grinding noise...i have no clue what it is, so far i have broken it down to the brake rotor, the rotor itself is scared but thats not the problem because there is nothing wrong with the brake pad itself...so i have no clue what it could be, someone at one point mentioned something about ball joints going bad but i dont know if i even have those...
some help on what might be causing the noise would be helped if any of you guys/gals out there have ever run into this problem
Old Aug 13, 2007 | 09:51 PM
dhvaughan's Avatar
dhvaughan
Default RE: Grinding noise in '02 1500 4x4
don't drive it. grinding is bad and it will do more damage somewhere.
you'll need to get it up on jack stands or something and rotate wheels and/or drivetrain to find the resistence and noise.
probably not ball joints. they are more likely to make a popping or clunking sound.
could be wheel bearings, brakes, diiferential, u-joints, transfer case, etc.
Old Aug 13, 2007 | 09:57 PM
Seanutz's Avatar
Seanutz
wow that alot of stuff i didnt want to hear...ive got nothing else to drive....looks like i have no choice tho, thanks for the help, hopefully its something simple and cheap to replace....
Sounds like its coming from closer to the rotor...like its coming from under the little dust hood...i think thats where the bearsing are but i dont know how to get to it....just take off the rotor?
Old Aug 14, 2007 | 08:45 PM
nastyram's Avatar
nastyram
had simular noise a few weeks ago turned out to be the hub bearing
