leveling kit help
Old Aug 14, 2007 | 05:34 PM
fannitti's Avatar
fannitti
Default leveling kit help
i want to do a leveling kit on my truck and i dont know what kind to use. i need the keys cuz i have a 05 1500 4x4. once i put the leveling kit in will i need to get differant springs and shocks? if so what kind? If not im planning on anyways changing my shocks and when i do, do i need to get off road ones or can i get normals ones for the truck? please help me thanks
Old Aug 14, 2007 | 07:07 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: leveling kit help
I have BD Performance leveling keys in my truck. Very happy with them so far! You probably wont NEED new shocks so no need to do them at the same time unless you have the money and want to. You wont need off road but i'd suggest getting them 2" longer than factory. You'll get back the 2" of travel you lose with stock height.
Old Aug 14, 2007 | 07:45 PM
aaronstottle's Avatar
aaronstottle
If you do get keys - you should probably make sure they're cast rather than unhardened steel.......
Old Aug 15, 2007 | 12:00 AM
ram2005hemi's Avatar
ram2005hemi
I had Ready Lift leveling keys installed on my 05 1500 4x4 SLT. Every pothole and speed bump afterwards caused the shocks to top out with a loud thud no matter how slow I went. I then made the mistake of replacing the shocks with stock replacement Bilstein's. They had the same problem, however I have read that some other people that have done the lift get by with the stock Bilstein's fine. I had to get the older Ram shocks for the front that are a few inches longer. I emailed Bilstein support when I was having the topping out problems and they recommended that I NOT get longer shocks because it would be hard on the ball joints, but the truck was almost undrivable over bumps. It was rediculous having to drive VERY slowly over speed bumps in a 4x4.
