4.10 OR 4.56
Old Aug 18, 2007 | 10:13 AM
  #21
ttuguy1983's Avatar
ttuguy1983
Default RE: 4.10 OR 4.56
anyone done them themselves?
Old Aug 18, 2007 | 11:05 AM
  #22
dodgeboy222's Avatar
dodgeboy222
larry wont do it for free, if jay does it, it will be making noise in 2 days. i'll charge you 5 hrs
Old Aug 18, 2007 | 12:36 PM
  #23
HammerZ71's Avatar
HammerZ71
ORIGINAL: BIGMC69
just ordered my gears today from krc parts 290.00. now as far as install i work in service at a chrysler dealership as an advisor so my techs will do the labor for nothing. also ordered 212x cams fro krc to install. looking for great performance.
Those are two great mods! You are gonna feel like you got a whole different truck...
Old Aug 19, 2007 | 10:33 PM
  #24
pershingd's Avatar
pershingd
Just finished breaking my 4.56s in and the difference is incredible. I haven't towed yet, but the MPG losses while not towing have been very small.
Old Aug 20, 2007 | 01:23 AM
  #25
cyclone429's Avatar
cyclone429
I would leave thee 4.7 totaly stock and step up to the 5.7 or CTD.
You don't have the displacment to turn 456 gears, esp when towing, Drag racing performance will be outstanding, but only on the bottom end.
Lose the 20 in rims and your mileage and towabilty will increase ( don't know standard rim size on the 1500 )
My 2500 hemi with just a 373 lt slip tows extreamly well, not better than a CTD, but good.
Old Aug 20, 2007 | 08:00 AM
  #26
eltupac's Avatar
eltupac
ORIGINAL: BIGMC69
Must be nice.
Old Aug 23, 2007 | 10:57 AM
  #27
BIGMC69's Avatar
BIGMC69
JUST INSTALLED MY GEARS 4.56 BOY DO THEY MAKE NOISE ANYONE ESLE WITH THAT PROBLEM???????????
Old Aug 23, 2007 | 12:11 PM
  #28
eltupac's Avatar
eltupac
Well, from what I know, noise = cheap gears or bad install(not properly set).
Old Aug 23, 2007 | 08:38 PM
  #29
helopilot's Avatar
helopilot
99% of noise is attributed to a bad install.
Old Aug 24, 2007 | 07:20 AM
  #30
HankL's Avatar
HankL
The most popular differential gear ratios of all time
are the 3.55 used by Chrysler, Dana, Ford, many others
...which has 39 teeth on the ring and 11 on the pinion
http://www.drivetrain.com/chrysler9.25.html
and the 3.73 which has 41 teeth on the ring and 11 on the pinion
and was long General Motors favorite ratio for their engines with shorter strokes
11, 39, 41
those are very special numbers.
What is special about them?
What are they called?
What does using that special number of teeth have to do with vibration and wear life?
Do 4.56 gearsets have the advantage of that number of teeth?
